Thread: Time to start thinking about a tune. Help
Results 1 to 16 of 16
  1. #1 Time to start thinking about a tune. Help
    Aug 2014
    North Alabama
    Ordered my Speed Daddy's yesterday. Gonna order my pulley this morning (3.4) and then get a mail order tune. A friend of mine that knows a lot about these cars says Overkill seems to be the way to go. Just want some of your guys opinions. I'm new to the GTP world. Just want to make sure I do everything right the 1st time if possible. Also, with a mail order tune do you have to email them things you want done? Like top speed limiter removed, increased line pressure etc.?
  2. #2 Re: Time to start thinking about a tune. Help
    Mar 2012
    NC
    Just headers may/may not allow you to drop to a 3.4 pulley bud. You should probably invest in some 1.9 rockers and valve springs before the pulley goes on.
  3. #3 Re: Time to start thinking about a tune. Help
    Jul 2012
    Chicago
    Depending on the car the 3.4 might be a bit much, as mentioned above. I have an Overkill tune, albeit on an NA car but I love it. Never heard any bad things about Overkill tunes, so I would buy with confidence.
    However, I should note... Where are you located? Might be able to get a member give you a proper in-car tune, geared towards your specific car.
    -Carl
  4. #4 Re: Time to start thinking about a tune. Help
    Aug 2014
    North Alabama
    I'm in North Alabama. There's a shop in my area that does dyno tuning. I asked on here if I should do a mail order tune or a dyno tune. Most seemed to think a mail order would be better. So hell, I guess it's still up in the air. I was planning on getting some 1.9's in the near future after the colder plugs, thermostat, pulley and tune. Scanned it 2 or 3 times with the Torquer Pro app. KR peaked at 2.1 Car is a 2000 GTP with 108k miles. I tried to add in my cars description in my sig but it said I don't have authorization to do so.
  5. #5 Re: Time to start thinking about a tune. Help
    If you already have a peak of 2.1 with headers (not sure if you installed them yet) a 3.4 will double that number.
    A tune might not take that away, just so you know. But I guess you'll have to see if it goes away when you install them, if you havent yet.
  6. #6 Re: Time to start thinking about a tune. Help
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Considering the OP says he ordered them yesterday, I'd say they are not installed yet... haha.
    Headers may or may not allow that much of a pulley drop as others have said, just make sure you scan with it after the header install.
    04 GTP -HAI, 1.9 rockers.
  7. #7 Re: Time to start thinking about a tune. Help
    Pfft reading.
  8. #8 Re: Time to start thinking about a tune. Help
    Aug 2014
    North Alabama
    So with headers, colder plugs, thermostat, air intake, and a tune you guys are telling me a 3.4 may be too much? Well that just sucks. And no the headers arent installed yet.
  9. #9 Re: Time to start thinking about a tune. Help
    Aug 2013
    Sandy, UT
    It may or may not be. Every car is different. Only way to know is to try it and scan. If you still have ANY KR I would recomend going up to a bigger pulley.
  10. #10 Re: Time to start thinking about a tune. Help
    Feb 2009
    flintnasty MI
    Tuning wont do much either way.
  11. #11 Re: Time to start thinking about a tune. Help
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I have an 04 comp g and put almost the same setup you're trying to do on early last month. SD headers, intake, colder plugs (2 stage), 180*t Stat and I got an overkill tune. Before I dropped pulleys I had no knock whatsoever for over two weeks. I monitored it almost everyday and it never had more than one or two instances and never more than .03. I put an intense mps on Oct 1st with a 3.5 pulley. Since then monitoring every time I go anywhere over a five minute trip, I'm seeing up to 2.5 degrees sometimes. Mostly less than one degree but occasionally over 2. You will still probably have knock on a Gen 3 at a 3.4 pulley with that setup. Maybe a dyno tune could get rid of more, but its a crapshoot. But, IMHO if its less than stock, I'm rolling with it. If it Blows, get another. That's my plan.
  12. #12 Re: Time to start thinking about a tune. Help
    Aug 2014
    North Alabama
    Whats the average KR on these cars when they're stock? I've read on here the average is usually 5-7 degrees
    2000 GTP coupe. Wizaired intake. 3.4 pulley, Overkill tune, and Speed Daddy's waiting to be put on.
  13. #13 Re: Time to start thinking about a tune. Help
    Aug 2013
    Sandy, UT
    Yeah average is anywhere from 2-10 depending on maintenance, heat etc.. Anything over 2* on less than a 3.8 pulley would have me concerned. But maybe thats because I just chipped a piston. on a 3.4/3.6 setup.
  14. #14 Re: Time to start thinking about a tune. Help
    The Boss Iceman6669's Avatar
    Jun 2011
    Meh. I kinda agree and disagree...
    It wont make your car much if any faster. BUT a tune can make it safer. Even if the pulley is too small you can take timing away/add fuel and kill off most if not all the KR. Not that the car is then tuned to be at peak performance but you CAN make the tune take care of the KR.
    2011 F-150 Yote powered
  15. #15 Re: Time to start thinking about a tune. Help
    Feb 2009
    flintnasty MI
    more PE fuel is the only "tune" thing i would ever do.
    might help, might make things worse...
  16. #16 Re: Time to start thinking about a tune. Help
    Aug 2014
    North Alabama
    more PE fuel is the only "tune" thing i would ever do. might help, might make things worse...
    What is PE fuel
  1. should i get a canned tune for the time being?
    By Doug 97 gtp in forum PCM Tuning
    Last Post: 06-09-2013, 03:12 PM
  2. Tune uup time
    By valente in forum General Tech Discussion
    Last Post: 06-04-2013, 04:20 PM
  3. Thinking it might be time for a new caliper.
    By FriboRage in forum General Tech Discussion
    Last Post: 01-21-2013, 11:49 PM
  4. Time for a tune?
    By DEC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 12:26 AM
  5. Tune Up Time
    By GPSims39 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2009, 10:19 PM
