Thread: Half Boost
Results 1 to 9 of 9
  1. #1 Half Boost
    Kemmerer, Wyoming
    My car is only making 4-5 lbs of boost. no engine codes, and the dic only displays half of the available bars. I'm at a loss of what it could be. I put a new BBV on and did the solenoid delete, I adjusted the BBV so its pushed all the way down.
    I've checked for vacuum leaks and havent found any. I'm wondering if it could be a bad MAP or a bad MAF. I 've also noticed a small amount of oil that has sprayed from someplace on the front of the engine possibly from a faulty valve cover gasket, but im not sure if its related.
  2. #2 Re: Half Boost
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Feel free to shoot me a picture of how the vacuum lines are set up on your blower. Still have my number from our chat the other day?
    We can go from there!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: Half Boost
    Kemmerer, Wyoming
    I don't have it, no caller id on the house phone
  4. #4 Re: Half Boost
    Kemmerer, Wyoming
    Pretty sure I did it right
    Half Boost Attached Images
  5. #5 Re: Half Boost
    Mar 2014
    Cincinnati, OH
    I can already see the problem.. That hose connecting the BBV to the gold T-fitting is causing the issue. You need to remove that hose and cap off the T-fitting on that end. You can leave that part of the BBV un-capped. It won't be an issue. That will fix it!
    2002 GTP sedan:
  6. #6 Re: Half Boost
    Dec 2010
    DMV
    Bingo
  7. #7 Re: Half Boost
    Kemmerer, Wyoming
    So the air will go into the bbv but not out
  8. #8 Re: Half Boost
    Dec 2010
    DMV
    Yup
  9. #9 Re: Half Boost
    Kemmerer, Wyoming
    Fixed, thanks for the help
  1. Only getting half boost on DIC.
    By ls1racer11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2012, 11:40 PM
  2. Half boost?
    By jgbigguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:56 PM
  3. Half Boost!!!
    By blackhawk gtp in forum General Tech Discussion
    Last Post: 11-03-2012, 12:10 AM
  4. only have half boost
    By gtp225 in forum Introductions/Noob Questions
    Last Post: 09-25-2010, 01:32 PM
  5. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
