Ever since i swapped to E85 ive noticed at times my car wouldnt run as good as i feel it does so i did routine maintenance new plugs wires oil change even the fuel filter and the car felt like a whole other car when i was done... when i looked at my spark plugs they look pretty bad they were ok before i switched to E85.. when you switch to E85 do you need to swap plugs,wires,filter simple maintenance? Thanks!
Sent from my LG-E980 using Tapatalk
