Thread: header install advice.
Results 1 to 18 of 18
  1. #1 Re: header install advice.
    GT Level Member gtphayes's Avatar
    Nov 2008
    harpers ferry, Wv
    i have a feeling my car's gaskets wont be good. the car it's self has over 200k miles on it. had a different motor put in. motor only has like 80k if that. so if its the 200k gaskets they should be replaced. and dang i forgot about the bolts being short. i think in the review someone said what size. i think ill wait to order them to make sure i get all the info right.
    ---under construction---
  2. #2 Re: header install advice.
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by gtphayes View Post
    The bolts work, but I just replaced them after a few weeks with longer one's because the one bolt looked like it was about to slip through the hole...
    Just get the basic header package and put them together to find out what you need, mine sat for months before I did it. Once we installed it, I realized it was not something I should have been so worked up about. Just do it.
  1. Bad vibration after header install
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 09:08 PM
  2. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
  3. ARP Header bolts
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-29-2008, 01:57 PM
  4. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
  5. SLP Header Installed
    By J_Ferguson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2008, 03:02 PM
