Thread: L26 to l67 swap possible
Results 1 to 4 of 4
  1. #1 L26 to l67 swap possible
    Sep 2014
    I just got a sweet deal on an 04 gt.
    Body is mint but the motor has a light knock. Only paid 500.
    I have a 98 gtp with a rebuilt l67 I was planning to sell anyway.
    What would it take to put the l67 in the 04?
  2. #2 L26 to l67 swap possible
    Aug 2013
    McDonald PA
    Nothing much. However j don't know the particulars Dsmuts did it. In his comp g
  3. #3 L26 to l67 swap possible
    Motor wise should be a direct swap but you'll probably want to get a gen v instead of trying to figure out how to get the right TB to work.
    04 Comp G.
  4. #4 Re: L26 to l67 swap possible
    Motor wise
    If you toss a Gen V/DBW TB onto it, should be easy. Swap the oil pan/pick up tube/motor mount. Put your alt bracket and alt on it. Then get the L32 Map sensor(s). Fix up the tune and off you go.
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
