Lately I bought a set of used 42.5lb injectors from a seller on the other wbody forum. The info were it was originally purchased from wbs store and flowmatched by DeatschWerks, they're EV1 connectors FWIW. When I got them each one were labeled 1-6 which I imagine the original owner labeled them for each cylinder. Anyways I installed them and when I went to check for leaks via priming the fuel rails, I noticed the one labeled “6” leaked at the area right between the injector itself as it was sealed tightly between the injector and the fuel rail and seated in the head. Below/attaqched is a pic of where I noticed fuel was leaking. I already contacted the seller on Saturday but no response yet :-\
Is the injector repairable? If so I might as well get them all repaired just in case.
