Thread: engine has rod knock
Results 1 to 16 of 16
  1. #1 engine has rod knock
    PA
    My 98 gtp developed a rod knock do these engines usually have issues with #1. Seems like that is where it is coming from
    What is the cheapest way to fix this issue I don't have much to spend
    Thanks
  2. #2 Re: engine has rod knock
    used engine is the cheapest route. start with cl local junk yards, and such,
  3. #3 Re: engine has rod knock
    gardner,mass
    Post a video of the sound.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: engine has rod knock
    GT Level Member SilverBulletWI's Avatar
    Apr 2014
    Milwaukee, WI
    ^^This. Had the same issue. Got the oil pan off to confirm rod knock/spun bearings. Then bought a used engine on craigslist. For me it's turned into an upgrade project going from a GT to supercharged with minor upgrades. But after research and advice from people on here including the above author...I found if you try to repair these engines after rod/crank issues, they won't last long.
  5. #5 Re: engine has rod knock
    Donating Users Uno99's Avatar
    Appleton, Wi
    Same thing happend to me. If you have a small budget junkyard/salavge is your best bet. Good luck man. Been alot of this latley.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  6. #6 Re: engine has rod knock
    PA
    Thanks for the info guys I found one from a 2000 gtp for $225 are there any major changes from 98 to 2000?
  7. #7 Re: engine has rod knock
    Nope.. change the coolant elbows and the bracket for the alternator..you should be all set
  8. #8 Re: engine has rod knock
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Nope.
    04 GTP -HAI, 1.9 rockers.
  9. #9 Re: engine has rod knock
    Appleton, Wi
    Nice find how many miles?
  10. #10 Re: engine has rod knock
    Technically the TB is different too. Either swap it out or consider updating the pcm
  11. #11 Re: engine has rod knock
    PA
    Thanks for the info is the 2000 tb any better than 98?
    Uno99 right around 120k
  12. #12 Re: engine has rod knock
    its not that its better or not, its maf wont work in your car, so just swap the whole tb to the new engine.
  13. #13 Re: engine has rod knock
    PA
    Ok thanks
  14. #14 Re: engine has rod knock
    Appleton, Wi
    Have fun with the swap keep us posted with pics of you progress.
  15. #15 Re: engine has rod knock
    Dec 2014
    Remington IN
    Why dont these engines take to rod/crank work?
  16. #16 Re: engine has rod knock
    Mar 2012
    NC
    Quote Originally Posted by jfrey View Post
    It's not that they don't...it's that people don't realize exactly what is required. Once the main caps are removed from the block, the block distorts and should be line honed to correct this. The rod bearings need to be checked VERY carefully due to wear on the crankshaft. I measure at least 3 times both the rod end and the crank and then still use plastigage to make sure I was right. Any abnormal variance means something is getting machined or replaced. Who wants to spend 6 hours on just measuring?
  1. help have engine knock.
    By twentyocho in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2013, 10:24 AM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
