Thread: Knock sensor?
Page 4 of 4 FirstFirst ... 234
Results 61 to 64 of 64
  1. #61 Re: Knock sensor?
    The Boss Iceman6669's Avatar
    Jun 2011
    I would open the TSTAT housing and pour water in and let it flow from the knock sensor hole.. Just let it keep flowing out. Then I would fill the car with pure water and let it run for a bit once everything is done and back together.. Drain it out. If it is clean fill with coolant and call good. If it is still dirty, repeat.
    2011 F-150 Yote powered
  2. #62 Re: Knock sensor?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Alrightyy
  3. #63 Re: Knock sensor?
    The build up is totally normal. I often have to poke through it when pulling a sensor. And yes.. that is about the lowest point in the block.
  4. #64 Re: Knock sensor?
    Aug 2011
    Michigan
    Alright. Freaked me out. Like literally made my heart skip about 15 beats o.O
    Yeah, it took probably another 2 ish gallons to fill back up
  1. Knock Sensor ???
    By dbextreme in forum General Tech Discussion
    Last Post: 03-18-2013, 10:49 AM
  2. Knock sensor ?
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2012, 05:54 AM
  3. knock sensor
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-09-2011, 06:52 AM
  4. Knock Sensor
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:51 PM
  5. knock sensor?
    Last Post: 10-20-2008, 12:19 AM
