Thread: Do I need a new belt?
Results 1 to 10 of 10
  1. #1 Do I need a new belt?
    Sep 2014
    Rhode Island
    Hey guys, so this weekend im probably dropping a pulley size. Im going from the stock size to a 3.6. I was just wondering if i will need a new belt, and if so how difficult is it to replace. Thanks.
  2. #2 Re: Do I need a new belt?
    no need, im on the stock belt on a 3.4
  3. #3 Re: Do I need a new belt?
    Sep 2014
    Rhode Island
    Do you have to do anything to the belt to make it fit?
  4. #4 Re: Do I need a new belt?
    nope, it goes back on the same way it came off.
    a 3.4 is smaller then a 3.6 so your pulley is just a bit smaller then a stock 3.8. it will just be a bit looser fitting.
  5. #5 Re: Do I need a new belt?
    Sep 2014
    Rhode Island
    Is that gunna effect the efficiency of it at all?
  6. #6 Re: Do I need a new belt?
    no. just use the stock belt, its more then ok.
  7. #7 Re: Do I need a new belt?
    Sep 2014
    Rhode Island
    Ok great thanks
  8. #8 Re: Do I need a new belt?
    Sep 2014
    Rhode Island
    Also, what tools will i need to take out the pulley?
  9. #9 Re: Do I need a new belt?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    If its the stock pulley you'll have to buy or rent a pulley puller.
    04 GTP -HAI, 1.9 rockers.
  10. #10 Re: Do I need a new belt?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Should you want it for this pulley, or plan on dropping sizes further, I have a one step smaller belt good for 3.3 through 3.7" pullies for sale. Let me know if you want it bud
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  1. sc belt
    By danomite02 in forum Wanted To Buy - Parts
    Last Post: 04-06-2013, 08:54 PM
  2. 3.6 do I need a new belt?
    By chevyy1212 in forum General Tech Discussion
    Last Post: 10-25-2011, 02:38 PM
  3. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  4. can you run the car without the SC belt?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:09 AM
  5. 3.4 belt
    By xsvtank in forum General Tech Discussion
    Last Post: 05-31-2010, 12:27 PM
