Thread: L67 with 191k. Worth the rebuild?
Results 1 to 20 of 21
  1. #1 L67 with 191k. Worth the rebuild?
    Mar 2012
    South Beloit, IL
    So I know everyone says not to rebuild the bottom end on these blocks because you just cause yourself a lot of problems. However, I want to make big power with a turbo setup and am afraid 191k says that a lot of parts are tired. There is nothing wrong with the engine that I am aware of, I am just afraid of putting all this power in and having something like a bearing go.
    Really, I want to rebuild the L67 and do a turbo setup because I am afraid the L36 in my GT will not be able to handle the turbo. If the L36 can handle 500hp, that would be fine. I would never push this car over that (at least not at this moment lol). I would top swap the L36, but for the money, turbos seem to be what everyone points to.
    Any opinions?
  2. #2 Re: L67 with 191k. Worth the rebuild?
    why not use the l36 if its got lower miles?
  3. #3 Re: L67 with 191k. Worth the rebuild?
    its a waster of money, dont bother. turbo what you got till it pops. then get a low miles n/a engine and just use that with your turbo if you every have too.
    a 3 or 400 dollar used engine is far better then a over 2 grand rebuilt bottom end. ( your not rebuilding it in your garage) it need lots of machine shop work.
  4. #4 Re: L67 with 191k. Worth the rebuild?
    Mar 2012
    South Beloit, IL
    The L36 only has 86k on it. So the L36 rods will be able to handle the horsepower?
    And yeah that was my fear. I'm not crazy enough to try to rebuild something like the bottom end in my garage. My co-worker insists it is easy and he has the knowledge, but I disagree with him. I just want to make sure I don't pop something shortly after doing this install.
  5. #5 Re: L67 with 191k. Worth the rebuild?
    your friend is dead wrong, this is not a 350 Chevy bottom end..........needs shop time...or make a bet with him, he can build it for you at his cost, if it lasts more then 500 miles you'll pay him, and when it blows up, hes buying you another engine too, .....see if he will take that BET cause the fail rate is that high. we call it a 200 mile engine. seen it happen every time ones rebuilt in the garage with zero machine shop work done.
  6. #6 Re: L67 with 191k. Worth the rebuild?
    this guys got two high miles turbo engines in this car. trannys are still the weak part,,,i say turbo what you got man......
    http://www.grandprixforums.net/threa...ine-walkaround
  7. #7 Re: L67 with 191k. Worth the rebuild?
    Mar 2012
    South Beloit, IL
    Lol I am on your side. I know these engines are ticking time-bombs when you do them yourself, I have read up some on it haha.
    He also says you should throw away 70% of what you read on these forums. I love these forums, best reference ever. He also said the oil pump was driven by the camshaft. Insisted that was wrong because I just got done doing a cam swap. And his GT has 2.93s. Also proved him wrong on that one. Let's just say I don't take his words of advice. We just both like Grand Prixs.
    And that is the sickest project car ever.
  8. #8 Re: L67 with 191k. Worth the rebuild?
    on old high miles engines too.
    offer your friend that bet, see if he bites......the forum said so lol
    he really thinks its a 305 block with two cylinders cut off dont he?? lol
  9. #9 Re: L67 with 191k. Worth the rebuild?
    Mar 2012
    South Beloit, IL
    Are those L36s he is using?
    And yeah, I would do it but I don't wanna piss him off lol. Fortunately we are friends, we just disagree on ALOT (obviously).
  10. #10 Re: L67 with 191k. Worth the rebuild?
    im not sure, hes got a build thread for the whole car too. could be n/a engines. people turbo them all the time. more bang for your buck over a top swap. but costs more.
  11. #11 Re: L67 with 191k. Worth the rebuild?
    Feb 2009
    flintnasty MI
    The parts that gwt tired are not even replaced durimg a rebuild.
    190k is not alot of miles.
  12. #12 Re: L67 with 191k. Worth the rebuild?
    Mar 2012
    South Beloit, IL
    That's good news. So would you turbo the L67 with 191k or the L36 with 86k? My target is ~500hp
  13. #13 Re: L67 with 191k. Worth the rebuild?
    Turbo the L67.. When it blows up swap over to the other motor...
    04 Comp G.
  14. #14 Re: L67 with 191k. Worth the rebuild?
    what he said^^^^^^^
  15. #15 Re: L67 with 191k. Worth the rebuild?
    Mar 2012
    South Beloit, IL
    Sounds good! Thanks
  16. #16 Re: L67 with 191k. Worth the rebuild?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I don't think 191K is high for these motors, unless a previous owner really beat on the car. I'm at 277K on my motor, no engine problems and still runs great.
    Of course, I'm just running the equivalent of a typical 3.4 pulley setup, the power of a turbo might be a different ball game.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  17. #17 Re: L67 with 191k. Worth the rebuild?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Stock trans still at that 277k miles?
    04 GTP -HAI, 1.9 rockers.
  18. #18 Re: L67 with 191k. Worth the rebuild?
    Knoxville, TN
    Quote Originally Posted by SnowTh1ef View Post
    Yes, actually. Lately the trans has been getting kinda goofy on hot days, TCC Lockup issues, codes etc... but excellent considering the age/mileage. Now that things are cooling down, it's behaving itself again. lol
  19. #19 Re: L67 with 191k. Worth the rebuild?
    Aug 2013
    Sandy, UT
    wow thats impressive. I barely believe that you still have your 4th gear haha. Gives me hope for my 156k car :P
  20. #20 Re: L67 with 191k. Worth the rebuild?
    Knoxville, TN
    I think the key is partly luck, probably more that the previous owners kept the vehicle stock and didn't beat on it. Lots of highway miles. No fancy transmission coolers or anything. They changed the trans fluid every 100k (twice), and I pan drop every 30k or so. Pulled the remains of a thrust bearing out of my last trans filter, so it's certainly not going to live forever.
  1. Axles worth a rebuild?
    By bps02gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2014, 07:59 PM
  2. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
  3. Is my car worth a rebuild?
    By LePrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2011, 05:09 PM
  4. Bio...is this worth the 30k
    Last Post: 02-14-2011, 09:24 PM
  5. How much do you think my car is worth?
    By EJOUIE in forum Off Topic Discussion
    Last Post: 05-06-2010, 12:08 PM
