Thread: What to look for when running a smaller pulley
Results 1 to 20 of 28
  1. #1 What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    I have a 3.5 on there now and I only see knock at wot between the 1/2 shift and it's only a 1.something, nothing major. I am looking to put on the 3.3 when the smaller belt arrives. I have done some reading and I see comments all over for yes or no. I have sd headers, 160 thermostat, cai and a gen v. I have hptuners for logging but I only use it when getting a log for my tuner. I also have an ultra guage (http://www.ultra-gauge.com/ultragauge/) that I have hooked up all the time.
    EDiT, I also have 3" exhaust, tr55's
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: What to look for when running a smaller pulley
    Antioch, IL
    A new engine because your already knocking.
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by ITHURTZ View Post
    Most engines have knock. Mine only shows up for a spit second during shifting as it bounces off the rev limiter during shift.
  4. #4 Re: What to look for when running a smaller pulley
    Antioch, IL
    Weird because mine doesnt......ever
  5. #5 Re: What to look for when running a smaller pulley
    GTP Level Member buickman104's Avatar
    NYC
    A 160 degree thermostat is too cold for your car and a 3.3" pulley is too small of a pulley for your setup. I would suggest you try a larger pulley than a 3.3".
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by buickman104 View Post
    How come it's too cold? I only drive the car in the summer. I have the 3.5 on there now.
  7. #7 Re: What to look for when running a smaller pulley
    Antioch, IL
    keep it on.. 160 dont mean jack really, its when the tstat opens, not what the engine will actually operate at, it will hit 200 if it wants to.
  8. #8 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    I have the t stat on the shelf, my motor rarely gets over 90 Celsius on a hot day. I just see the lower t stat as a supporting mod that's why I picked it.
  9. #9 Re: What to look for when running a smaller pulley
    Howell, NJ
    It doesn't really "support" anything
  10. #10 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    So what's the point of the lower thermostat other than to open earlier. And why do they make a 160 degree one if it's too cold?
  11. #11 Re: What to look for when running a smaller pulley
    Howell, NJ
    I dunno. For racekars?
    All is does is slow the temperature climb to operating temp.
  12. #12 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Jomamma View Post
    Mine takes a while just to get to 90c so I guess I'm good there.
  13. #13 Re: What to look for when running a smaller pulley
    Aug 2014
    Maple Grove, MN
    Quote Originally Posted by tweeder View Post
    ouch. you should raise your rev limit a couple hundred RPM if you raised your shift points. I'm pretty sure when you hit the rev limit the car shuts off fuel which can be catastrophic and maybe the cause of of your KR.
  14. #14 Re: What to look for when running a smaller pulley
    May 2008
    Schuyler, NE
    How much timing are you running?
  15. #15 Re: What to look for when running a smaller pulley
    you have a fiero so you should be able to get away with smaller pulleys than the typical wbody guy because your car is much lighter, thus less load on the engine.
  16. #16 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    Not sure it varies from 15-30 ish
  17. #17 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    I was just thinking, I see on the mod list for running a smaller there's cams and what not. What about a turbo? Why can we run a turbo with I'm assuming more boost and again assuming less problems?
  18. #18 Re: What to look for when running a smaller pulley
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    turbos make immensely less heat and are immensely more efficient. Two 100% different animals, that cannot be compared. A turbo 3800 car can make more power with basically no supporting mods than a maxxed out m90 car can with heads/cams etc.
    04 GTP -HAI, 1.9 rockers.
  19. #19 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by SnowTh1ef View Post
    Ahh I see I was looking at it as a boost level comparison.
  20. #20 Re: What to look for when running a smaller pulley
    Aug 2013
    Sandy, UT
    Boost is by no means a power comparison. A stock l67 makes like 6 psi. a stock l67 but with a turbo instead of an sc on 6 psi is a 100% different machine. turbo and 6psi will get you into the high 13s. A stock gtp is like low/mid 15s. lol
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 08-05-2014, 07:10 AM
  2. Smaller Pulley on '00 GTP
    By usdmaf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2014, 08:05 AM
  3. Do I really need a smaller belt with my smaller pulley?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-04-2014, 12:36 PM
  4. How Long Have You Been Running A Smaller Pulley?
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 09:13 AM
  5. smaller pulley
    By kunkelz28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2010, 02:01 PM
