Thread: What to look for when running a smaller pulley
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    Since it's not the boost levels that's the problem, what is the problem with the sc applications and smaller pulleys? I know that fuel is the number one as without that, yeah fireworks.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #22 Re: What to look for when running a smaller pulley
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Smaller pulley=much hotter air charge.
    Heat=KR.
    theres a reason these SC's are called "Heatons"
    E85, race gas, Cam, or intercooler would be the next thing to prevent knock and allow a lower pulley.
    04 GTP -HAI, 1.9 rockers.
  3. #23 Re: What to look for when running a smaller pulley
    Aug 2013
    Kitimat, B.C.
    I get the kr part and I'm scanning for that once I drop down again. How does the cam play into lower kr? The time the chaimbers stay open.
  4. #24 Re: What to look for when running a smaller pulley
    Aug 2013
    Sandy, UT
    More flow, and usually lowers boost, reducing restriction, allowing you to spin the SC faster.
  5. #25 Re: What to look for when running a smaller pulley
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Superchargers are like 35% parasitic on an engine whereas a turbo is like 0% parasitic. I read that on these forums somewhere back a few years ago.
    Because of the extra energy the engine has to use to turn the supercharger through the belts and everything, it is parasitic. A turbo, which is spun by the exhaust gasses, is not parasitic. Thats why at the same boost level, a turbo will help produce more power
  6. #26 Re: What to look for when running a smaller pulley
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by tomtom123 View Post
    Not trying to nitpick you, you are mostly right, just want to point out that there are some parasitic losses with using a turbo. The turbo behaves like an exhaust restriction to some degree, which necessitates the engine working somewhat harder. Can't say exactly how much harder. Still worlds more efficient than the M90, though.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #27 Re: What to look for when running a smaller pulley
    Antioch, IL
    +2mpg so it cant be that much of a exhaust restriction, made the rest of the exhaust hella quiet though
    2009 Challenger SRT8
    Expert at being gay.
  8. #28 Re: What to look for when running a smaller pulley
    Aug 2011
    Michigan
    It's a restriction to a point, but nothing noticeable really. I mean making it turn truly isn't that hard seeing how you can spin their turbines rather fast just by hand =o
    But yes, I can kinda see where you're coming from. And it's okay, I don't mind being corrected.
    Truly what I should have said was the turbo is very slight loss if anything. But it kinda makes up for it =P
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 08-05-2014, 07:10 AM
  2. Smaller Pulley on '00 GTP
    By usdmaf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2014, 08:05 AM
  3. Do I really need a smaller belt with my smaller pulley?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-04-2014, 12:36 PM
  4. How Long Have You Been Running A Smaller Pulley?
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 09:13 AM
  5. smaller pulley
    By kunkelz28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2010, 02:01 PM
