Thread: Replacing upper engine mount bracket.
Results 1 to 20 of 37
  1. #1 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    Yes it is a series 2.. And thanks for ur help.. I just ordered the zzp CAI and am now hoping it will work. I just installed ported throttle body and tb spacer and am wondering it will all fit.
    Sent from my SCH-I535 using Tapatalk
  2. #2 Re: Replacing upper engine mount bracket.
    Oct 2011
    Toledo, OH
    Quote Originally Posted by grazin View Post
    The ZZP box looks like it is smaller than the Wizaired, so you should be fine.
    7"
  1. Need engine mount bracket for 05 gtp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-15-2014, 06:28 PM
  2. P/S upper engine mount
    By Sven the Sexman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2012, 09:41 AM
  3. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  4. Cracked upper motor mount bracket
    By vailskier3 in forum 04+ Specifics
    Last Post: 04-16-2012, 02:11 PM
