Thread: Replacing upper engine mount bracket.
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #1 Re: Replacing upper engine mount bracket.
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    COMP Cams#249-76-802-9 Xtreme Energy 264HR-15 Hydraulic Roller Camshaft Lift: .531/.531
    Duration: 264/274
    Lobe Separation Angle: 115°
    RPM Range: 1000-5500
    The cam I am currently running =]
  2. #2 Re: Replacing upper engine mount bracket.
    ^ traitor.. Thought u were running the VS >_<
    04 Comp G.
  3. #3 Re: Replacing upper engine mount bracket.
    Aug 2011
    Michigan
    Me? =P
    Nah. Been running this since I bought it from Alix0r ;P
  4. #4 Re: Replacing upper engine mount bracket.
    The Boss Iceman6669's Avatar
    Jun 2011
    Stock tune should run it OK even with the TB. But the TB will throw off the fuel trims. So a good custom tune should be on the list.
    2011 F-150 Yote powered
  5. #5 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    Yea , I have a tuner for my ls2 Gto , but not sure if he would be comfortable tuning my l67.. He uses HP tuners, so I'm not sure if he could tune.. He mostly tunes on ls motors
    Sent from my SCH-I535 using Tapatalk
  6. #6 Re: Replacing upper engine mount bracket.
    Kemmerer, Wyoming
    I put a zzp hvtb on my last gtp and it ran fine. I am curious why you went with the 130 lb springs with that extreme energy cam. the powerband is from 1000 to 5500 so im curious what you are revving it to. I am considering this cam because it should do good with the 90 lb springs I have
  7. #7 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    Actually it was recommended to me when I bought the cam package.. interestingly enough, I broke a spring doing a burnout.. And was surprised because I never thought I'd break one..
    I installed plugs, wires and coils because I had 70,000 on them and was getting around d 7 degrees of knock.. Figured I'd get a hvtb whole I was at it..
    Car runs so much better at part throttle, but when I get into it, I'm still seeing allot of knock..
    Anther forum guy suggested I change my o2's since they are stock.. That and I need to get a custom tune.. I currently run a canned tune
  8. #8 Re: Replacing upper engine mount bracket.
    Kemmerer, Wyoming
    You could put a bigger pulley on it to help reduce the knock
  9. #9 Re: Replacing upper engine mount bracket.
    Kemmerer, Wyoming
    I spent about 18 months of my life at fort eustis.
  10. #10 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    I'm only running a 3.4 with a can and full exhaust.. I've been told I should be able to go smaller with my mods
  11. #11 Re: Replacing upper engine mount bracket.
    Aug 2011
    Michigan
    Cam, 3.4, full exhaust as in catback? Or full exhaust as in headers and everything?
  12. #12 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    Yea headers back
  13. #13 Re: Replacing upper engine mount bracket.
    Aug 2011
    Michigan
    Okay.
    Hmm... 7° is quite high for a cam/headers/proper exhaust work/3.4"/tune
    I mean could be a really screwey tune, but I would think even with a crappy tune you would see less than 7°
    All your plugs okay?
    Any misfires?
    No codes?
  14. #14 Re: Replacing upper engine mount bracket.
    Kemmerer, Wyoming
    If you have that much knock them something needs to change
    Sent from my KFJWI using Tapatalk
  15. #15 Re: Replacing upper engine mount bracket.
    Aug 2011
    Michigan
    I have a cam/3.4"/headers/no cat/partial tune/AL 104's and I see up to 8.1° of knock but I am convinced that knock is because I way overtightened my knock sensors. Neither of mine are at 14 ft-lbs =/
  16. #16 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    When I took my old plugs out, they where really white which to me ment too lean. However I would on very hot days would get a p0420 code I've got a high flowing cat . so I'm thinking its an o2 sensor.. Could they cause a lean condition? They have 112,000 on them..
  17. #17 Re: Replacing upper engine mount bracket.
    Mar 2013
    Norfolk va
    Speaking of knock sensor's... Should they be replaced? Car is a 2003 with 112,000 miles and knock sensors are original.
  1. Need engine mount bracket for 05 gtp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-15-2014, 06:28 PM
  2. P/S upper engine mount
    By Sven the Sexman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2012, 09:41 AM
  3. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  4. Cracked upper motor mount bracket
    By vailskier3 in forum 04+ Specifics
    Last Post: 04-16-2012, 02:11 PM
