Thread: Dropped pulley size? Keep the stock belt
Results 1 to 3 of 3
  1. #1 Dropped pulley size? Keep the stock belt
    Apr 2014
    Albuquerque New mexico
    I know that most when they drop pulleys get a shorter belt which is an okay solution but thought id do this write up as to save people some money and also get a better wrap on the supercharger pulley. I'm sure this has been written up Before but I have never seen it and I doubt that there was a listed part number.
    so if you are running a 3.4 (that's the size I'm running) you can forsure run the stock sized belt and this pulley. This pulley, the pulley you will be swapping out is the tensioner pulley on the supercharger belt. The correct part number for over sized pulley is AUTOZONE/DURALAST #231081 if you don't want to get this at auto zone it is listed in there system as a 1990 c3500 7.4 with ac idlers pulley. This cost only 17$ which is much less then a new quality belt (gatorback or gates) This pulley is a stout steel pulley just like oem and fits perfect. The size quite a bit larger and take all slack out of the factory belt.
    This is completely took care of any slip that I had on the supercharger pulley which got my boost back up to 9.5 lbs when I was seeing 8 at most before the upgrade/replacement of this pulley.
    Will upload pictures when I get on the computer
    also if admin sees this fit somewhere else please move it
  2. #2 Re: Dropped pulley size? Keep the stock belt
    Mercer, Pa
    Looks like that 90mm OD or 3.54". Pretty sure that the size of some of the other idler pulleys on the L67.
    I want a 95mm or 100mm which is 3.75 to 4.00".
  3. #3 Re: Dropped pulley size? Keep the stock belt
    Apr 2014
    yeah it should be 90mm i dont think anything bigger would fit, this one touched the idler pulley until the belt was re installed.
  1. Pulley help along with belt size
    By nd4spdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2013, 01:12 PM
  2. What size belt do I need for a 3.6 pulley?
    By szalajka05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2012, 06:17 PM
  3. Gatorback Belt size for stock S/C?
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2011, 03:44 PM
  4. belt size question for 2.8 pulley
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2009, 07:33 PM
  5. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
