Thread: custom ported heads and cam combo
Results 1 to 6 of 6
  1. #1 custom ported heads and cam combo
    Kemmerer, Wyoming
    I have a set of heads ported by Chris Hinson. I am trying to decide which cam to use. He suggests his heads do well with the XP cam. If I run the xp cam do I use the 130 or 140 lb springs or can I use the 90 lb springs? I have a set of 90 lb springs already and would like to use what I have so save on costs. I am also considering a VS cam because it will do well with 90 lb springs and I already have them.
    Looking for advice on which cam/spring combo to use.
  2. #2 Re: custom ported heads and cam combo
    s1x and 105 springs because im bias....... LOL or use the xp cam and 130 springs.
  3. #3 Re: custom ported heads and cam combo
    Oct 2011
    Puyallup WA
    Use what you have and don't Rev it to high...or sell 90's to fund at least 105lb
    08 G8 GT - exhaust Tune
  4. #4 Re: custom ported heads and cam combo
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I have 105's on a cam very similar to the XP. Holding up just fine. I know a few other guys with the same cam as me and they have their revs at like 6.3k? Give or take. And they have mileage on their setups holding up just fine.
  5. #5 Re: custom ported heads and cam combo
    Florida
    if the heads were ported with the Xp cam in mind then that is the cam you should run.
  6. #6 Re: custom ported heads and cam combo
    The Boss Iceman6669's Avatar
    Jun 2011
    90# springs run just fine on the XP cam.
    2011 F-150 Yote powered
  1. Ported heads
    By sseilmnop in forum Wanted To Buy - Parts
    Last Post: 08-04-2014, 12:02 PM
  2. Ported heads ?
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2013, 02:13 PM
  3. Ported heads flow #'s
    By sd98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 01:53 PM
