Thread: Engine randomly kills. At a loss
Results 1 to 4 of 4
  1. #1 Engine randomly kills. At a loss
    Mar 2012
    South Beloit, IL
    Hey guys,
    Not really sure what could be causing this problem or if it could be transmission related. Basically, every once in a while when I start to accelerate from a stop (doesn't matter how hard), the car will randomly kill. It is completely unpredictable and only happens once while I am driving. Happened today on my way to work and it took 5-6 tries of turning it over for it to finally catch and keep running. All the other times, it would catch maybe once or twice, then kill. Amazingly, once it catches, car runs like there was never a problem in the first place. Also, no SES codes.
  2. #2 Re: Engine randomly kills. At a loss
    Check for a loose connector at the ICM. If that is good, then tap on the maf with it running. When that passes the tap test.. I'd probably shotgun a crank sensor onto it.
  3. #3 Re: Engine randomly kills. At a loss
    Mar 2012
    South Beloit, IL
    Yeah crank sensor was my initial thought.. I'll give that all a try tomorrow (no access to tools today) and return with results, Thanks.
  4. #4 Re: Engine randomly kills. At a loss
    You can do the first two.....even at the drive thru of a mcdonalds..while waiting in line.
  1. 97 Grand Prix Engine Randomly Cutting Out
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2014, 02:57 PM
  2. Engine dies randomly, but starts right back up
    By habbiflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2013, 01:57 PM
  3. Engine Idles Fine, Kills when I Hit the Gas
    By Liquid86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-24-2013, 04:18 PM
  4. Engine whines and loses power randomly
    By Storm Smith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2012, 10:57 AM
  5. Engine Power Loss
    By Israel Toledo in forum General Grand Prix Discussion
    Last Post: 06-19-2012, 08:43 AM
