Thread: pulley mod requirments
Results 1 to 9 of 9
  1. #1 pulley mod requirments
    Jun 2012
    spencer
    hey guys
    so im looking at getting a smaller pulley for my supercharger i have a 98 gtp and im just checking on here to see what all additional mods i would need for different sizes because i have found alot of different answers on the internet. im just looking at a 3.4 and 3.35 the zzp website recommends their pcm tstat and colder plugs and for the nothing about the 3.35 on the website though. is it possible to put on the 3.35 with the same mods needed for the 3.4? and do i need all the mods right away? or will everything run just fine without them for a while?
  2. #2 Re: pulley mod requirments
    the difference between a 3.4 and 3.35 would make them useless to have both.
  3. #3 Re: pulley mod requirments
    Please stop listening to ZZP's site. It's outdated and very wrong. Please read the safely modding your car thread on this site.
    Thanks
  4. #4 Re: pulley mod requirments
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    http://www.grandprixforums.net/showthread.php?t=67580
    Read this about 2 times and you should have a pretty good idea =)
    I read it a few times as well. Good info
  5. #5 Re: pulley mod requirments
    If you're wanting a 3.4 you'll need at least headers.
  6. #6 Re: pulley mod requirments
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by tigers40 View Post
    hey guys
    1. Get a scanner. Aeroforce, ScanGauge, Torque App, etc. Scan for KR - knock retard. It happens when the computer senses the engine is pinging (the fuel is predetonating) and yanks timing to compensate. It works, but there's two limitations... first, it kills power, and second, to yank timing there must have been knock in the first place. Not good. When the piston is moving down, and the explosion is going up... the explosion wins every time. Chipping a piston means its time for a new motor.
    2. Most cars have a couple degrees of KR in stock form, and that's only when they make about 6# of boost. Don't pulley down without at least a downpipe, or for a 3.4, headers and a tune. Any less is inviting a motor swap. I had KR with a downpipe and 1.9 rockers on a 3.5 pulley. Speed daddy headers are like $200. Do supporting mods first, then pulley down.
    3. After headers, then pulley down to the 3.4 or 3.5 range... and get it tuned pronto. A canned tune (Intense, ZZP, etc.) will work at this point but an in-car or dyno tune would be best.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: pulley mod requirments
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by hensleya1 View Post
    This.
    Tune will make or break your car.. it will make a fast car slow and a slow car fast
    Sent from my LG-E980 using Tapatalk
  8. #8 Re: pulley mod requirments
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Completely agree with the above. Every car is different.
    With headers, AL104's, 180t-stat (mostly placebo mod anyway) and a 3.5 pulley my car still had KR on the stock tune.
    I bought HPT used from a member on the forums, scanned and tuned myself. Now I have different tunes for running 3.6 , 3.5 , 3.4 safely, and have the opportunity to change boost, timing, AFR, etc. to experiment with all different combinations without blowing up the motor.
    If I had just thrown a 3.4 on without scanning, even though the internet said I was perfectly safe, I probably would have destroyed my motor.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  9. #9 Re: pulley mod requirments
    Has someone suggested a 2.8 yet?
  1. Modular SC pulley and hub, water pump aluminum pulley
    By MattStrike in forum Wanted To Buy - Parts
    Last Post: 03-12-2013, 08:03 PM
