Per Scotty-
open the rad cap (while car is cold), start engine and let the car idle till the fans come on, then open the bleeder screw till a solid stream of coolant comes out. then shut the screw, top off the rad,and cap it.
if your having a heat problem, take the hoses for the core off the engine and flush/fill the core. bleeding the engine wont help get the heat back.
