Thread: Codes and Dying
Results 1 to 7 of 7
  1. #1 Codes and Dying
    Apr 2014
    Maplewood
    Hey everyone,
    I have a 2000 GTP that is throwing the MAF code and misfire code. It runs alright sometimes and runs very rough or just flat out dies other times.
    I am going to swap out the MAF when I get home, but if that is not it - does anyone have any other ideas?
  2. #2 Re: Codes and Dying
    check the fuse box for a blown fuse, @ 26 iirc or 27.
    what code you getting? theres more then one maf code. low voltage one could be the fuse or bad wires to the maf.
    dont use a after market maf. best to get a used oem maf, they run around 40.
  3. #3 Re: Codes and Dying
    Apr 2014
    Maplewood
    I don't remember the specific code, I'll run the scanner when I get a break at work and post the specific code.
  4. #4 Re: Codes and Dying
    Apr 2014
    Maplewood
    Alright, I got the codes, they are as follows:
    P0102
    P0128
    P0300
    and another p0102
  5. #5 Re: Codes and Dying
    Quote Originally Posted by CNorell145 View Post
    P0102
    P0128
    P0300
    and another p0102
    running cold..need a t stat is my guess, like its stuck open. https://www.google.com/search?q=P012...m=122&ie=UTF-8
    low voltage check the wires and fuse. http://www.obd-codes.com/p0102
    the po300 is misfires multiple. last tune up? maybe time for one.
    car off unplug the maf, then start it. if it runs better most of the time the maf is bad.
  6. #6 Re: Codes and Dying
    Apr 2014
    Maplewood
    Can you drive it without the MAF for short times, or should it just idle?
  7. #7 Re: Codes and Dying
    if it runs better yes, just dont go beating on it. drive like an adult.
    dont remove it, just unplug it.
  1. My car keeps dying on me.. Help..
    By Akcalvinkid in forum General Tech Discussion
    Last Post: 04-09-2013, 03:01 PM
  2. She's Dying.
    By ThirtySix in forum General Tech Discussion
    Last Post: 04-02-2013, 09:52 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. 01 gt dying a lot
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 09:18 PM
  5. Car keeps dying
    By jakeeck in forum General Tech Discussion
    Last Post: 02-19-2009, 12:26 AM
