So, Here is a little more information for you all,
Went out to look at the car after it had been sitting for a few days. Checked all the fluids, poked around in the engine compartment a little bit and didn't see anything out of the ordinary. Climbed inside and plugged in my scanner and found 15 codes, some of them being duplicated. Here they are:
C0450 - Steering Assist Control Actuator Circuit
C0035 - Left Front Wheel Speed Sensor Circuit Malfunction
P0101 - Mass or Volume Air Flow A Circuit/Performance
P0102 - Mass or Volume Air Flow A Circuit no input
P0121 - Throttle /Pedal Position Sensor A Circuit Range/Performance
P0332 - Knock Sensor 2 Circuit Low input (Bank 2)
P0730 - Gear Ratio Incorrect
P1810 - Tranmission Fluid Pressure Valve Position Switch Circuit
Cleared the codes and started it up. Ran rough for about a minute then she settled down. I then took it for a few mile test drive and all seemed well. headed up to visit my parents about twenty miles away and made it eight miles before she acted up again. pulled in a parking lot, let her sit for a minute, cleared the codes, and drove home. the list of codes generated after it misbehaved was as follows:
Any input is greatly appreciated.
Josh
