ok so here we go, I have beein having an issue with my 2003 gtp. The first problem that arose was a check engine light with 2 codes, po443 and po102. so the first thing i did was hop on the forum and do a little research and from what i found these two are on the same fused circuit and it referred me to check fuse #21 for the ignition, sure enough this fuse was blown.
So then i replace the fuse just as a "hey maybe this will work" and of course it immediatly blows and throws the same two codes back up so then i research some more and dig into the harnesses and right next to the MAF on the harness there is two broken wires nice to each other so i go ahead and fix the harness and think that things shouldbe cleared up now. just got back in from testing it out and the fuse has blown again....
Where do i go from here? Thanks for the help.
