Starter is a ok... Spark plugs were dead as f**k replaced plugs on which now my tps code is gone just a egr code now replaced fuses fuel pressure regulator even swapped icm's replaced icm relay no go any more suggestions could crankshaft position sensor be the culprit? No code for it but ive a code doesnt have to be set for it to be bad any ideas guys?
Sent from my LG-E980 using Tapatalk
icm coil packs (all 3) tps sensor maf sensor all off my car just to check and eliminate the guessing didnt change anything. Has plenty of fuel from the valve on the rails and new fpr. The whole no codes is throwing me for a loop too i sure dont get it either...
Checked all the fuses under the hood and swapped the 2 of the relays around no different so they were swapped back to the way they were.
I have a suggestion, but your apparently an Askhole. See FB for definition. It's going around. lol
