Thread: Need help on Rebuild
Results 1 to 20 of 24
  1. #1 Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Got the motor in a running drove it around and as soon as i pull in the driveway it dies out 4 codes pop up
    P0122
    P0405
    P0403
    P1122
    P0122 and P1122 are TPS related (Throttle Position Sensor) and the P0403 and P0405 are Egr related .. i swapped tps sensors still the same codes pop up i even splice the harness from another car because i thought it was the actual harness any more ideas? Could it be the throttle body? Would i need to replace it? The angle of the metal piece inside where the tps meets? thanks
    Sent from my LG-E980 using Tapatalk
  2. #2 Re: Need help on Rebuild
    Check the fuses both under the hood and in the glove box. That's a lot of codes chances are some are related if not all of them.
    I think the EGR ones can be tuned out since the car doesn't have EGR on it anymore. Could be wrong Im sure others around here will know
  3. #3 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Correct they can be tuned out i'll check the tps fuses and or fuse and see any more reasons i really dont think its the throttlebody
  4. #4 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Anybody know the correct fuse for the throttle body position sensor?
  5. #5 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Check this vid out guys:
    http://youtu.be/TNxaRDivgXo
    It is like its fighting/choking with itself..
    Codes are same tps and egr related
  6. #6 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Anybody?
  7. #7 Re: Need help on Rebuild
    HUDSON
    Sounds like the firing order not correct.
  8. #8 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by QUICKSILVER462 View Post
    Firing order? I hooked the plugs in the correct order and double checked
  9. #9 Re: Need help on Rebuild
    HUDSON
    Get yourself a scanner so you can see all the functions of the sensors and verify they are reading correctly.
  10. #10 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Checked sensors and my tps and maf are at the right volts cant be my throttle body it was working on my last setup screen isnt f**ked has to electrical everytime i try and start it like its suckin juice from the battery and the starter checks out good any ideas?
  11. #11 Re: Need help on Rebuild
    Try swapping the tps?
  12. #12 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Swapped the tps dsmuts bad maf seems like the issue like my last build
  13. #13 Re: Need help on Rebuild
    Not having much luck lately
  14. #14 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Not but i'll figure it out
  15. #15 Re: Need help on Rebuild
    Mar 2012
    NC
    Isn't there a fuse specifically for the TPS and EGR? Check your fuses to make sure.
  16. #16 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    No i really dont which fuse are for the tps and egr but the egr can get tuned out
  17. #17 Re: Need help on Rebuild
    Go back to your grounds. Fix the one that is nearly broken or totally broken. Remember the two small wires.
  18. #18 Re: Need help on Rebuild
    Banned
    Jan 2013
    maryland
    Ok i'll check grounds
  19. #19 Re: Need help on Rebuild
    You do know the two wires I'm talking about ..right?
    The two you cooked when you hooked them to the starter... those two. I'd bet the cooking was bad for them.
  20. #20 Re: Need help on Rebuild
    or..all the movement.. one broke off it's eyelet
  1. car shakes when stopped at light and brake is held please help
    By Project98GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-18-2015, 09:42 PM
  2. held coilover mounts
    By 91parkave in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2013, 11:47 AM
  3. what hand held Tuner works better
    By ferret81 in forum PCM Tuning
    Last Post: 09-14-2013, 08:34 PM
  4. Held off a GTP
    By dmahlikGT in forum Track Sessions and Kills
    Last Post: 06-23-2011, 10:38 PM
  5. HELD Coilovers Installed!!
    By JashGTP in forum Visual/Body Modifications
    Last Post: 05-17-2008, 12:46 AM
