Thread: 2000 GTP RPM stalling out issue
Results 1 to 20 of 24
  1. #1 2000 GTP RPM stalling out issue
    GT Level Member Yarbeau's Avatar
    Jun 2010
    Edmonton
    Hey guys, my brother is having some issues with his 2000 GTP coupe.
    He says the RPMs will bounce around hitting 5k slamming down to 0 bounce back up and the car will then die. Its not a constant issue, happens a few times a week for the last month. Now it died on the road last night and wouldn't start back up so he's waiting on a tow home. The car went down to 0 RPM the traction control and oil light came on and the car died. No fluid leaks everything is full fluid wise.
    Any ideas what could be wrong with the thing? plugs, wires and coils would be where I would start. Anything beyond that?
    Here is a brief list of what I know has been done to it.
    Headers
    down pipe with cat delete
    3.4 pulley
    throttle body spacer
    MSD wires
    MSD coils
    K&N
    Aeroforce gauge
    Oil, temp, boost gauges.
    Custom tuned PCM
    Thanks so much for the help in advance. this forum works miracles.
    2000 Daytona 500 - Tog Headers with catted Downpipe, EGR Delete, 180* Thermostat, Solid engine mount, Poly tranny mount/Dogbones, K&N CAI with a custom tune.
  2. #2 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    We got it to start but it won't stay running longer than 5 minutes.
    Swapped PCMs in it, put stock wires and coils on. Still nothing.
    No codes are being thrown for misfires or anything. Put a new fuel filter in... No help.
    Any ideas?
  3. #3 Re: 2000 GTP RPM stalling out issue
    St. Louis
    So you were driving along and the tach dropped to 0 before it shutoff? If so, this sounds like a classic symptom of a bad crankshaft position sensor. They usually don't set a code either. The sensor is behind the balancer towards the 3 o'clock position. Check the wiring to it. If all checks out there then might be time to pull the balancer and replace the sensor.
    If you do end up replacing the sensor, be sure you locate the keyway on the balancer correctly w/ the crank before you hammer the crank bolt back down or you will cause other issues. It happens all too often, lol..
  4. #4 Re: 2000 GTP RPM stalling out issue
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    ^ this is what I was thinking. And yes, if you do remove the balancer make sure the keyway lines up with the groove on the balancer!! I recently cammed an L67 and put it back together correctly. Then had an oil leak in the seal behind the balancer and replaced that but forgot to put the balancer back on the keyway. Had to replace the balancer and was thankful I didn't wreck the keyway/tooth on the crankshaft! But don't risk it. Make a checklist or something and on that list put down to make sure you put the balancer groove on the keyway and make sure to quadruple check it.
    Sent from my SM-N900P using Tapatalk
  5. #5 Re: 2000 GTP RPM stalling out issue
    Pull a plug or two.. are they wet? If so.. they don't smell like fuel I'd bet.
    If that's the case, get a TB gasket, remove that TB spacer and throw it away.
  6. #6 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Perfect thanks so much guys. I'll be going over there tonight and seeing what I discover. I had previously pulled the plugs and they weren't wet or carbon'd up.
    Thanks for the replie my friends!
  7. #7 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Ok so we pulled it apart and changed the crankshaft sensor. Making sure to quadruple check the keyway. The car hasn't changed.
    Thought the problem went away when taking it for a test drive. 15 minutes later we were stranded yet again.
    ANY other ideas? Im open to anything. Need to get this car up and running for him.
    Thanks guys.
  8. #8 Re: 2000 GTP RPM stalling out issue
    Aug 2011
    Michigan
    Does it run for 15 mins, then run really bad, then stall? Or does it run fine and just stall?
  9. #9 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Runs like normal sputters 2 or 3 times and then stalls out.
    Once they mentioned crank sensor it made sense. Runs fine, loses crank positioning and shuts off. But I guess that isn't the case. I checked all the wires running from the sensor and everything is in great shape.
    I'm stumped.
  10. #10 Re: 2000 GTP RPM stalling out issue
    Aug 2011
    Michigan
    Hmm. I ask because I had a bad fuel pump. Car would run for 15 minutes and then shut off. But the car would run really bad and then stall. After 15 mins the fuel pressure would drop to like 15 - 20 psi then drop to about 10 and die
  11. #11 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Quote Originally Posted by tomtom123 View Post
    Interesting. could be his issue to. Its not like its an instant die. It sputters 2 or three times and then dash lights up with Traction control/abs and then it dies.
  12. #12 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Forgot to mention I changed the fuel filter in it thinking that could be the culprit. This was before I checked plugs and wires etc.
    Could it be the fuel pump or something to do with fuel supply? Should be able to read that on the aeroforce and see if its cutting off due to lack of fuel.
  13. #13 Re: 2000 GTP RPM stalling out issue
    Aug 2011
    Michigan
    Could be. I'm sure not everyone has the exact same issue when something goes bad. Like mine after 15 mins would run like crap at about 15 - 20psi but would keep running a few more minutes. I suppose it could just die right out too
  14. #14 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Ill take it for a spin tonight and monitor fuel. This is really getting to me and its not even my car!
    Thanks for the tip tomtom
  15. #15 Re: 2000 GTP RPM stalling out issue
    Aug 2011
    Michigan
    Does it do the same thing if the car is just idling in park for 15 mins?
  16. #16 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    I don't know. Havent tried that. Will give it a shot.
    I've just bee going over there and giving the kid a hand. Will let it run and see if it still dies out.
  17. #17 Re: 2000 GTP RPM stalling out issue
    Aug 2011
    Michigan
    Okay
  18. #18 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    Ok so heres an update.
    When the car dies it takes 15-20 minutes to turn fire back up again. it turns over and is getting a spark but won't fire until it has cooled down.
    I went over there last night but the kid had his keys with him. I changed the msd coils back to stock (again because he is convinced the MSD ones are solid, I'm not) and swapped the bottom plate those sit on for one i had sitting around.
    Wasn't able to track fuel as I couldn't start the car.
    Could it be a bad cam sensor? I talked to a mechanic friend about it and thats what he thinks. But i figured id ask the pros before attempting another job that might not solve the issues.
    Thanks guys.
  19. #19 Re: 2000 GTP RPM stalling out issue
    Jun 2010
    Edmonton
    So it was the ignition control module (Plate underneath the coils) that was at fault..
    Changed that and the problem has gone away. Thought I'd update just incase someone else was having the same issue in the future.
    Put the MSD coils back on to see if it was the coils and not the plate. Turns out it was definitely the plate.
    Thanks guys.
  20. #20 Re: 2000 GTP RPM stalling out issue
    St. Louis
    Good to know. And when he starts having misfires again, pull off those MSD coils and reinstall the stockers and drive on. They don't call them "My Spark Disappeared" for nothing, lol...
  1. Stalling Issue....Please help
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2012, 07:15 PM
  2. 2000 grand prix gt stalling issue
    By 2000gts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2011, 08:36 PM
  3. Stalling Hot Issue Need Help...
    By BPGPSE in forum General Tech Discussion
    Last Post: 06-13-2010, 09:26 PM
  4. New Here and Have Stalling Issue
    By BPGPSE in forum Introductions/Noob Questions
    Last Post: 06-12-2010, 07:14 PM
  5. MAF / stalling issue
    By the1euge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 11:16 AM
