Thread: Fuel issue
Results 1 to 14 of 14
  1. #1 Fuel issue
    Sep 2013
    Goldsboro, NC
    So I just did my 1.9 RR upgrade and PLOG, crossover and rear PEM last week. After getting everything back together the car runs amazingly well now and finally 0 KR through first and second with a spike of 1-2* KR on downshifts for about a second. The problem I'm having now is after the car has set turned off for about 30 minutes or longer and I try to start it, it doesn't want to fire up on the first attempt but will on the second. If I turn the key to "on" position and let the fuel pump prime it will fire right up. I guess I'm losing fuel pressure somewhere. Any ideas? I've tried spraying carb cleaner all around fuel lines under the hood while running and can't find any leaks.
    Thanks in advance,
    Tate
  2. #2 Re: Fuel issue
    Maybe the regulator is going bad.
  3. #3 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Is there a way to check this? Anyone else have any ideas?
  4. #4 Re: Fuel issue
    Mar 2012
    NC
    Sounds like a regulator. Put a fuel pressure gauge on and see if it's holding pressure.
  5. #5 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Well now the car will not start at all. I thought maybe fuel pump resistor and tried bending the tab on the relay and the car would run really rough for about two minutes then die and not start up again at all. Changing the relay pin back and reinserting it made the car start and run normally until I got on the road and tried to return home. Ran fine for about a minute up the road then completely died and now will not start again regardless of the fuel pump resistor relay tab being bent or not. With the relay in it's normal "position" meaning no tabs bent the pump comes on every time the key is turned on for about 3 seconds then stops.
    I ordered the fuel pump resistor off line and it should hopefully be here tomorrow. Any other ideas to try? I need to find a way to at least get the car back to the house so I can do something with it and out of the church parking lot where it made it to.
    Tate
  6. #6 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Any other ideas out there?
    Tate
  7. #7 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Swapped out fuel pump resistor with a new style version and it fixed the problem. Also seems to start up right away every time as well now. Just in case anyone else is having this issue.
    Tate
  8. #8 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Well the losing pressure problem is back. Anytime the car sits for more than about an hour when I go to start the car it will not start the first attempt but just turn over. After I release the switch and try again it starts right up. If I let the fuel pump prime first it will start up but it still takes about 2 seconds to start. I don't have a fuel pressure gauge to attached to the rail. Any other way to check it to see if it's the fuel pressure regulator? I would hate to spend $60 on the part if that's not it. Any help here would be great.
    Thanks in advance,
    Tate
  9. #9 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Anyone have any information on this that might be helpful?
    Tate
  10. #10 Re: Fuel issue
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Hmm. What year is the car?
    Sent from my SM-N900P using Tapatalk
  11. #11 Fuel issue
    Grab a fuel pressure gauge from harbor freight for $20 or just go to the parts store and put down essentially a deposit for the cost of the tool and then you get your money back when you return it
    04 Comp G.
  12. #12 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    It's a 2000 GTP. No Harbor Freight around, so I guess I'll have to hit up Autozone and see if they have one. What is fuel pressure suppose to be at constantly on the rail? 52-54 psi? Also if it is bleeding pressure off is the fuel pressure regulator the only thing that would cause it?
    Tate
  13. #13 Re: Fuel issue
    you want to see over 42 psi. key to on, and running.
    anything under 40 is a problem.
    parts store should also sell the pressure gauge for around 20 if you want to own it.
  14. #14 Re: Fuel issue
    Sep 2013
    Goldsboro, NC
    Thanks, Scottydoggs.
  1. Fuel ISSUE!!! E85
    By J2000 in forum General Grand Prix Discussion
    Last Post: 01-22-2014, 01:26 AM
  2. fuel issue?? 99 gtp
    By jman44 in forum Introductions/Noob Questions
    Last Post: 12-20-2013, 06:29 PM
  3. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  4. Fuel issue
    By Blowblackorgetback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2012, 06:34 PM
  5. Another issue, fuel? please help!
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-22-2010, 12:28 AM
