So I just did my 1.9 RR upgrade and PLOG, crossover and rear PEM last week. After getting everything back together the car runs amazingly well now and finally 0 KR through first and second with a spike of 1-2* KR on downshifts for about a second. The problem I'm having now is after the car has set turned off for about 30 minutes or longer and I try to start it, it doesn't want to fire up on the first attempt but will on the second. If I turn the key to "on" position and let the fuel pump prime it will fire right up. I guess I'm losing fuel pressure somewhere. Any ideas? I've tried spraying carb cleaner all around fuel lines under the hood while running and can't find any leaks.
Thanks in advance,
Tate
