Thread: Can't get into gear
Results 1 to 18 of 18
  1. #1 Can't get into gear
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    So I go to put it into gear. Nothing. But if I push the button to realse it. It goes into work any idea
    2001 sliver gtp her name is Reagan
  2. #2 Re: Can't get into gear
    Jan 2014
    AR
    So when you move the gear selector to "D", you get nothing? Or will the shifter not move? Check the transmission fluid level first if the car just won't move. If its that low, you'll need 3 or 4 quarts plus you have a leak to fix before you cause damage.
  3. #3 Re: Can't get into gear
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    How many quarts of transmission fluid is needed after a filter change?
    Sent from my SM-N900P using Tapatalk
  4. #4 Re: Can't get into gear
    Aug 2013
    McDonald PA
    Quote Originally Posted by tomtom123 View Post
    8 quarts
  5. #5 Re: Can't get into gear
    Aug 2011
    Michigan
    I put 7 in mine and it didn't even register on the dipstick. I checked with the transmission temp at like 170 and car running idling in park. I put 2 more in, still nothing. I put like 3 more in and now its within the lines on the dipstick. Unless I somehow miscounted the 7 quarts Autozone said I needed and sold to me =P
  6. #6 Re: Can't get into gear
    Oct 2012
    Fort Wayne, Indiana
    Won't move shifter unless I press the button realse
  7. #7 Re: Can't get into gear
    Oct 2012
    Fort Wayne, Indiana
    Drives great
  8. #8 Re: Can't get into gear
    Feb 2013
    37.295091, -121.930053
    also it could be a connection under the console not getting enough power. i noticed when you unplug it. it wont go into gear
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: Can't get into gear
    Oct 2012
    Fort Wayne, Indiana
    Right after motor swap btw
  10. #10 Re: Can't get into gear
    Jan 2014
    AR
    Quote Originally Posted by 98buicksupercharged View Post
    If its not what Eric said:
    Try STANDING on that brake pedal HARD one time. Theres an interlock present that may be interfering. Still no go? Is the key release working OK?
    On the ATF level, I had one of mine upside down for about 40 minutes and lost about a gallon. Wouldn't move until she gulped down about three quarts so the level has to be fairly precise just so it will move. By the way if you ever want a super nasty mess, mix ATF and mud together and sling it under the hood!
  11. #11 Re: Can't get into gear
    Feb 2013
    when i did my motor swap i put in a 1200 cold cranking amp battery yeah a bit over kill but it worked
  12. #12 Re: Can't get into gear
    Oct 2012
    Fort Wayne, Indiana
    Well car broke down on way home. So have to fix it first lol
  13. #13 Re: Can't get into gear
    open the console you have a broken wire to the shiftier.
    what broke down? i guess you got that new problem under control?
  14. #14 Re: Can't get into gear
    Oct 2012
    Fort Wayne, Indiana
    Don't know yet. Was driving perfect for a hour around town. So we thought we were good. So I went to go home on the high way. On the high way it started bucking and Rpms jumping all around. And then died. Car starts right back up but when you go to take off Rpms start jumping all over the place. Runs perfect at idle. And in park and neutral when revved
  15. #15 Re: Can't get into gear
    Feb 2013
    sounds like a bad crank sensor to me but........ does it have MSD coil packs on them by chance?
  16. #16 Re: Can't get into gear
    sounds like Reagan needs a good old fashioned kick in the CVNT. if you know what i mean lol
  17. #17 Can't get into gear
    Possible CPS
    04 Comp G.
  18. #18 Re: Can't get into gear
    Oct 2012
    Fort Wayne, Indiana
    I'll figure it out. And yes she deserves a great big kick. All in all though the engine ran strong and great for the first 40 minutes. The motor I got runs very well. On first start up it even started on the first crank. so I'm very happy I got a great motor from the junk yard. And no. Hell no. No msds
  1. gear set, 4th gear hub, channel plate gouged! help!
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2013, 04:54 AM
  2. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  3. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    Last Post: 11-12-2012, 12:18 PM
  4. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
