Thread: Sputters under WOT
Results 1 to 20 of 20
  1. #1 Sputters under WOT
    May 2014
    Winnipeg
    Hey guys
    I got a 2002 GTP a couple months ago, and up until a couple weeks ago, it ran great! Then it started to sputter a little if I'd give it too much throttle. The engine light came on and I got a guy to scan it. It turned out cylinder 3 was misfiring. So just as a test I changed that plug. I can't do much at the moment because I have a broken wrist. Since this problem happened, I did the fuel filter, air filter, cleaned the MAF, ran some fuel line cleaner stuff, and changed the one plug. I have a set of plugs and wires coming from ZZP. I always run the highest octane fuel I can get. The only mod on the car that I can tell is the exhaust has been done.
    After I changed the one plug, I did notice a difference and it ran a bit smoother, but still sputters when I'd give it some gas and it gets to around 30km/hr. Sometimes it smooths out again. The car also has much less power. Should I just see what the new plugs and wires do? Any other ideas?
  2. #2 Re: Sputters under WOT
    Feb 2013
    37.295091, -121.930053
    what pulley size are you running. also is this thing moded? if so are you scanning for KR? did you also get a pic of the plug when you took it out?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Sputters under WOT
    It sounds like you are on the right track as far as where to start, I would try and get the rest of the plugs changed out, then do your wires when they come in. If that doesn't work I would check the coils, ICM and the fuel injectors. Oh and also check for a vacuum leak.
  4. #4 Re: Sputters under WOT
    Quote Originally Posted by Garet View Post
    Hey guys
    I think he answered that.
  5. #5 Re: Sputters under WOT
    May 2014
    Winnipeg
    Thanks for the quick response. I believe it is the stock pulley. How do I tell for sure? The previous owner told me all he did was exhaust. I forgot to mention the old plug. It looks like this.
  6. #6 Re: Sputters under WOT
    Looks like a platinum plug, but I could be wrong. What are the numbers on the side of it?
  7. #7 Re: Sputters under WOT
    May 2014
    Winnipeg
    Oh! I also checked coils. I forgot. They're good too. How would I check ICM, fuel injectors and for a vacuum leak?
  8. #8 Re: Sputters under WOT
    Dec 2012
    troll land
    oreillys will test icm for free, you just have to take it off first. my wot sputter was from the icm
  9. #9 Re: Sputters under WOT
    May 2014
    Winnipeg
    Quote Originally Posted by Slick2500 View Post
    It says ACDelco 125683874 and also 41-101
  10. #10 Re: Sputters under WOT
    May 2014
    Winnipeg
    Quote Originally Posted by l67ss View Post
    I am in Canada. We don't have those. Could mechanics do it...or would I have to go to a GM dealer?
  11. #11 Re: Sputters under WOT
    Yeah have the icm tested.
    To see if its a fuel injector you would take the fuel rail off, don't disconnect the fuel lines though, but make sure you relieve the fuel pressure. Go to Oriellys and pick up fuel injector orings for all 6 fuel injectors for a total of 12, carefully pull out the number 3 injector put new orings on it, then take out one other injector put new orings on it and put the one you just removed in the number 3 spot and put the number 3 injector in the now open spot, remember where you put the injector, now one at a time replace the orings on the rest of the injectors. Now see if the misfire follows the injector.
    To check for vacuum leaks, while the car is running you can spray carb cleaner on the vacuum lines if you have a vacuum leak the car will bog down if it sucks carb cleaner into a vac line.
  12. #12 Re: Sputters under WOT
    What part stores do you have in Winnipeg?
  13. #13 Re: Sputters under WOT
    Dec 2012
    troll land
    yeah I think napa, autozone, advance all test icms for free
  14. #14 Re: Sputters under WOT
    Napa dont do **** for free.
  15. #15 Re: Sputters under WOT
    May 2014
    Winnipeg
    This might be a dumb question...but is the ICM the thing under the coil packs?
  16. #16 Re: Sputters under WOT
    Yes it is.
  17. #17 Re: Sputters under WOT
    May 2014
    Winnipeg
    That wasn't the problem. I switched it out with the one in my brothers car and my car still does the same thing.
  18. #18 Re: Sputters under WOT
    What plugs did you put into the car?
    Sent from A Galaxy Far Far Away........
  19. #19 Re: Sputters under WOT
    May 2014
    Winnipeg
    I'm waiting on the plugs. I just tried one NGK plug in the misfiring cylinder. I ordered 6 NGK TR6 sparkplugs off ZZP.
  20. #20 Re: Sputters under WOT
    May 2014
    Winnipeg
    It seems plugs and wires were my problem. Thanks for the help everyone!
  1. Car sputters when accelerating hard
    By joemama22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2015, 12:53 PM
  2. Car sputters when trying to boost
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-26-2012, 06:31 PM
  3. 97 gtp. Sputters on startup
    By djs4021 in forum General Tech Discussion
    Last Post: 10-26-2011, 12:55 PM
  4. car sputters really bad
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 11:31 PM
  5. Sputters on start, sometimes
    By busagtp in forum General Tech Discussion
    Last Post: 05-20-2010, 07:22 AM
