Thread: bogging issue in cammed l67
Results 1 to 14 of 14
  1. #1 bogging issue in cammed l67
    Apr 2014
    Nova Scotia, Canada
    I just recently done a rebuild on my l67..its in a 98 grand prix GTP..during the rebuild I added a cam, its a stage 1x blower cam from intense racing.c on, made by cam motion. I now have my engine back together but I can no longer build boost. As soon as my in dash boost gauge goes over half my engine bogs and sputters and looses power..has anyone had this problem? Any fixes?..anything you've got would be helpful
    Thanks!
  2. #2 Re: bogging issue in cammed l67
    Donating User Odi's Avatar
    Chicago South Suburbs
    Do you have a properly tuned PCM? If yes, who tuned it/is it a shelf tune?
  3. #3 Re: bogging issue in cammed l67
    when you say rebuild, how much was rebuilt? was a machine shop used?
    could be a vac leak. spray some carb cleaner around the engine at idle.
  4. #4 Re: bogging issue in cammed l67
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Check your spark plug gapping, if they are gapped at .60 then they are to open . Try gapping at .45.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  5. #5 Re: bogging issue in cammed l67
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I thought .60 was roughly ideal?
    Sent from my SM-N900P using Tapatalk
  6. #6 Re: bogging issue in cammed l67
    .55 here
    But I would mess either the ago first or try replacing them. Plugs are stupid cheap anyways if they're copper that is
    04 Comp G.
  7. #7 Re: bogging issue in cammed l67
    * I would mess with the gap first * since the edit button wants to be gay
    04 Comp G.
  8. #8 Re: bogging issue in cammed l67
    The more power you make, the less gap is used, most of the time.
    I run .050 personally, stops chances of idle misfires and I don't have to worry about anything else. I would agree that .060 is too big for a cammed car.
    I want to guess at either misfires or a plugged cat is causing it to bog down.
  9. #9 Re: bogging issue in cammed l67
    Apr 2014
    Nova Scotia, Canada
    No machine shop used, built in my shop..I've built engines before but this is my first non n/a..I don't have a lot of experience with superchargers before this build. I double checked my vacuum lines, they're good. I'll check the plug gaps tomorrow and see what they're set at, and I'll try .50 and see if that works. I will update tomorrow after work..thanks everyone!
  10. #10 Re: bogging issue in cammed l67
    Aug 2011
    Michigan
    Ahh I see. Good to know. I just cammed my GTP and am hopefully dropping the engine in on Friday. Glad to know to gap plugs to .050 ish =P
  11. #11 Re: bogging issue in cammed l67
    so you put all new bearings and rings in with out line honing the mains? if so thats your problem right there, the good old 200 mile motor. its letting go on ya little by little.
    these 3800 need machine shop work or they go boom, its not a small block chevy, this block will twist some if the crank is pulled.
  12. #12 Re: bogging issue in cammed l67
    Jan 2009
    Any updates?
    Sent from my LG-D959 using Tapatalk
  13. #13 Re: bogging issue in cammed l67
    Apr 2014
    Nova Scotia, Canada
    I gapped the plugs to .50 and she runs like a top..slight shift lag but other than that I have no complaints..thanks guys!
  14. #14 Re: bogging issue in cammed l67
    Yay
    04 Comp G.
  1. Cammed gtp vs. 04-05 sti
    By sic40th in forum Track Sessions and Kills
    Last Post: 07-16-2012, 11:35 AM
  2. Is my car cammed
    By tigers40 in forum General Grand Prix Discussion
    Last Post: 07-06-2012, 11:42 AM
  3. wierd bogging issue
    By 91gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-23-2010, 10:16 PM
  4. going cammed?
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2010, 09:28 AM
  5. cammed 3.1 SE
    By ricardo23 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-12-2009, 05:36 PM
