Thread: AC/Heat not working properly and vacuum problem
Results 1 to 4 of 4
  1. #1 Re: AC/Heat not working properly and vacuum problem
    a top the sc is a tree with 3 vac ports, one to the brake booster, one to the boost solenoid, and the 3 rd is the hvac vac line, it runs to the fire wall, then to the pass side fender, down under the fuse box where it could T ( some have a T some dont, if you have a T one side runs across the front rad support to a vac ball. the other side merges with a loom of wires under the fuse box then runs into the cab of the car.
    if you pull the pass side carpet up you'll find the vac line coming in the car and follow it to the box it plugs into.
    see the line to the fire wall?
  2. #2 Re: AC/Heat not working properly and vacuum problem
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    Yea I actually cracked the line in half it's hard and I moved it a little and it snapped I had to rig something.. I wanted to redo the vacuum lines anyways but I can't find out what the sizes are from anyone.. but I have to look under windshield washer fluid / fuse box area when I get time and see if it's messed up there if not then in the car
  1. DIC Not Working Properly
    By MattF in forum General Grand Prix Discussion
    Last Post: 03-23-2014, 08:20 AM
  2. DIC Not Working Properly
    Last Post: 03-22-2014, 09:40 PM
  3. sunroof not working properly
    By BoostnBlackGTP in forum General Tech Discussion
    Last Post: 02-20-2011, 06:39 PM
  4. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
  5. problem #2.. #5 on heat control not working
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 12:13 PM
