Thread: Can you replace the altenator without taking the blower off
Results 1 to 13 of 13
  1. #1 Can you replace the altenator without taking the blower off
    Banned
    Jan 2013
    maryland
    Gonna swap my 97 for a 99+ wanted to know can I just take it out without taking the blower or anything else off?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Can you replace the altenator without taking the blower off
    Yea
    04 Comp G.
  3. #3 Re: Can you replace the altenator without taking the blower off
    Mar 2012
    NC
    You can...you'll need a 99+ alternator, bracket, and some coolant elbows and coolant.
  4. #4 Re: Can you replace the altenator without taking the blower off
    Yup
  5. #5 Re: Can you replace the altenator without taking the blower off
    Banned
    Jan 2013
    maryland
    Can I reuse my aluminum one?coolant will need to be replaced why?
  6. #6 Re: Can you replace the altenator without taking the blower off
    Mar 2012
    NC
    Coolant runs through the alternator bracket. 99+ alternator brackets use two coolant elbows while the 97-98 bracket uses only one. The two alternator brackets are completely different from each other due to the way the alternator mounts.
  7. #7 Re: Can you replace the altenator without taking the blower off
    although...they tension the belt the same...lol
  8. #8 Re: Can you replace the altenator without taking the blower off
    Dec 2012
    troll land
    you prolly have the second elbow leftover, just get new o-rings for the one ur currently using and put them both in
  9. #9 Re: Can you replace the altenator without taking the blower off
    Banned
    Jan 2013
    maryland
    Ok i'll do that also my altenator wire has a short could I cut the burnt portion and splice my new wire ?
  10. #10 Re: Can you replace the altenator without taking the blower off
    Where is the short? If it's close to the connector, I'd pickup a new piggytail and solder it on.
  11. #11 Re: Can you replace the altenator without taking the blower off
    Banned
    Jan 2013
    maryland
    Bill the short is close by other harnesses. . I couldn't just splice the wire? I dont have a solder gun on me
  12. #12 Re: Can you replace the altenator without taking the blower off
    you can cut and splice it, or use a butt connector for a temp fix till you can get to soldering iron. solder will out last the wire.
  13. #13 Re: Can you replace the altenator without taking the blower off
    Banned
    Jan 2013
    maryland
    I'll splice for now then use a lighter and when I can a soldering gun i'll grab one
  1. How-To: Replace the Blower Motor on a 2000 Grand Prix
    By WalterWhite in forum How To Write-Ups/Tech Tips
    Last Post: 09-04-2015, 12:00 AM
  2. Altenator Short?? Help
    By GTP4EVER97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2011, 03:14 PM
  3. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  4. Chirping noise coming from altenator/tensioner only when cold.
    By Beauty026201 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2010, 06:39 AM
  5. help removing altenator case
    By chitownchevy in forum Off Topic Discussion
    Last Post: 09-16-2008, 06:47 AM
