Thread: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
Results 1 to 11 of 11
  1. #1 Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Banned
    Jan 2013
    maryland
    Started the car after I cleaned the maf and air filter and because of a code im getting for the maf and next thing the car shuts off!.. odd so I turn key to prime the fuel and I dont hear the fuel priming by the rails nor the gas tank so the fuel pump just took a dump... but my question is the fact that my maf is getting a code could be why my car is runnin rich? Bad fuel pump? Fuel filter change? Also im still getting a lot of kr which could climb to 14.9 but could that because of fueling becsuse I dont have boost being as I took the belt off thanks
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Unplug maf.. likely it's your issue
  3. #3 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Banned
    Jan 2013
    maryland
    Check your pm billboost
  4. #4 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    I checked... and I lazily responded.
    Jist of pm.
    He has a maf code and KR.
  5. #5 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Banned
    Jan 2013
    maryland
    Replacing the fuel filter any tips on getting it off? I dont want to strip the bolt even those its rusted and its by the fuel lines so I definitely dont want to do that
  6. #6 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Soak the threads with penetrating oil let it sit and use the appropriate wrench size.
  7. #7 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by 94GrandPrixSE View Post
    I did... the bolt is rusted really bad on there
  8. #8 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Nebraska
    Try using a flare wrench it always has done the trick for me.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  9. #9 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Banned
    Jan 2013
    maryland
    The one that grips all sides of the bolt?
  10. #10 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    I unhook the quick connect side, Put vice grips on both the line nut and the filter. Turn filter while holding the line nut steady. That way you will not hurt the rusty crusty line
  11. #11 Re: Ok so my car dumps fuel into the spark plugs car running rich what could it be?
    Banned
    Jan 2013
    maryland
    Thanks i'll try that sounds way better
  1. Running too rich?
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2013, 09:43 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
