Thread: Throttle Body Cleaning--Seeking advice
Results 1 to 9 of 9
  1. #1 Throttle Body Cleaning--Seeking advice
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 GTP, L67, 141k miles, open cone air filter
    I want to clean my throttle body. I have read and googled and youtubed too much--a lot conflicting information, hoping to find some solid advice/insight to couple seemingly basic, simple questions. FWIW, I am NOT going to seafoam the TB on the car.
    1st, the throttle body has coolant ports, so is there coolant in it, that is, if I remove the throttle body is any fluid going spill out?
    2nd, the throttle body has MAF sensor, IAC valve, and TP sensor, right?
    3rd, I have already removed and cleaned both the IAC valve MAF sensor, but I am unsure about the TP(?) sensor. Should I be concerned about fouling out the TP sensor if leave it in TB while I spray it with TB cleaner? Does removing/replacing TP sensor require PCM or other calibration, relearning, programming, whatever?
    I know, total noob questions. Like I said, I've come across all kinds of conflicting info. Today is the perfect day for this, except I have commitments tonight and can't be without my only car. Thanks in advance!
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  2. #2 Re: Throttle Body Cleaning--Seeking advice
    You can leave the tps in. There will be a very slight amount of coolant come out but don't worry about it.
  3. #3 Re: Throttle Body Cleaning--Seeking advice
    Nov 2011
    Chicago
    Thanks dsmuts! That leads to a follow up. Wouldn't removing the TB then require bleeding the coolant to remove air pockets?
  4. #4 Re: Throttle Body Cleaning--Seeking advice
    No it'll be fine
  5. #5 Re: Throttle Body Cleaning--Seeking advice
    Nov 2011
    Chicago
    Great.
    THANKS again
  6. #6 Re: Throttle Body Cleaning--Seeking advice
    Nov 2012
    Madison
    Here is some pictures.
    http://www.gpona.com/forums/do-it-yo...ody-t3899.html
    Literally just did mine again, the rough idle was popping up once in awhile.
  7. #7 Re: Throttle Body Cleaning--Seeking advice
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    When I cleaned mine I ever took it off. Layed a brick on the gas pedal to hold the throttle plate open and sprayed carb cleaner into it till it ran out clean.
  8. #8 Re: Throttle Body Cleaning--Seeking advice
    GTP Level Member buickman104's Avatar
    NYC
    Quote Originally Posted by lewis1952 View Post
    The OP is supercharged. This method wouldn't be beneficial to him as the carb cleaner might eat away his rotor coating.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  9. #9 Re: Throttle Body Cleaning--Seeking advice
    Sep 2013
    tulsa okla
    Thanks for the info. I know absolutely nothing about super chargers.
  1. Cleaning Throttle Body
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2012, 08:00 AM
  2. throttle body cleaning
    By dlk in forum General W body
    Last Post: 05-19-2012, 09:37 AM
  3. Cleaning the IAC, MAF and throttle body
    By Nicolecc2 in forum Engine
    Last Post: 08-29-2011, 08:48 PM
  4. cleaning throttle body
    By mtz956 in forum General Tech Discussion
    Last Post: 06-15-2011, 06:29 AM
  5. Cleaning Throttle Body 04-GP
    By mpbrown18 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2010, 12:29 AM
