Thread: oiling issue... where is it going
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: oiling issue... where is it going
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    lower than it was a few days ago.. and i pulled cap... got moisture in cap.. only time i see that is when it rains... weird huh
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #22 Re: oiling issue... where is it going
    hows the over flow tank? is it full? or empty?
  3. #23 Re: oiling issue... where is it going
    brunswick
    a little under the hot line
  4. #24 Re: oiling issue... where is it going
    thats normal then, if its full and over flowing thats a head gasket, or if its empty its a head gasket.
    you can also when its warmed up some, rad cap off, rev the engine watch the rad for bubbles. if you see bubbles the head gasket is bad.
    then theres the good old co test for the rad, it will tell you if exhaust gas is in the engine's coolant. aka blown head gasket. not a cheap test kit to buy. around 60 bucks or so iirc.
    being you got oil on the plugs, (not coolant) and low compression. still looks like bad rings.
  5. #25 Re: oiling issue... where is it going
    brunswick
    ok.. cool.. well ill continue as planned and grab that block
  6. #26 Re: oiling issue... where is it going
    You just dont have any luck with these cars do you, this makes what car number 3 in the past 2 years?
  7. #27 Re: oiling issue... where is it going
    brunswick
    lets seee........ first gp in 2010 broke trans once and rack and pinion twice.. sold after second time.... second gp 2011 rod knock.. fixed it.. trans ****ted... patched.. sold it with no 4th gear................ uhhh 1987 caprice.. in 2012 sold it.. running..... now i have a 03 bonneville and the gp.. that now has either ****ty rings or ****ed up something....
  1. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  2. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  3. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  4. oiling problems
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2009, 05:59 PM
  5. Rear oiling port???
    By gixer2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:12 AM
