Thread: oiling problems
Results 1 to 7 of 7
  1. #1 oiling problems
    Plattsburgh,NY
    I just bought a 98 grang prix for 400.00 today. it isn't getting oil to the heads any suggestions. My other option is to drop a 92 3.8 in will it bolt up. I know it has different motor mounts I can drill and tap mounting holes if needed.
  2. #2 Re: oiling problems
    TDCRacing
    Guest
    How do you know it is not getting oil to the valvetrain?
  3. #3 Re: oiling problems
  4. #4 Re: oiling problems
    Banned - Busted For Scamming
    Feb 2009
    what is the oil pressure? cam bearings? main bearings? rod bearings?
  5. #5 Re: oiling problems
    Plattsburgh,NY
    The valves are making niose and I pulled off the oil cap and can't see any sign of oil splashing around.
  6. #6 Re: oiling problems
    Feb 2009
    you probably wont, its not that much as like a sbc. youre going to have to verify someother how, could be possible has bad lifters
  7. #7 Re: oiling problems
    Wichita, KS
    They don't splash as said. If the engine is running, you look through the oil fill hole into the head. Looking closely at the oil in the bottom of the head, you will see some tiny air bubbles. If these bubbles are moving....slowly...then you have oil pressure to the top end.
    The noise could be a collapsed lifter, to maybe even a rocker that is loose, and off its valve.
    A visual inspection first, can save you a lot of headaches in the future.
    For starters, I would rent from a parts store, like Oreillys or autozone a oil pressure test kit, or just buy one, Harbor Freight has some decent ones pretty cheap. (nice tool to have in the garage BTW) Hook it up and see what the actual pressure is.
    ~F~
  1. Problems with my 04 GP
    By 04gpking85 in forum 04+ Specifics
    Last Post: 10-17-2009, 02:15 PM
  2. Got some problems with my '04
    By 04gpking85 in forum General Tech Discussion
    Last Post: 05-24-2009, 02:50 PM
  3. Having Problems...
    By GP3800TC in forum Turbo
    Last Post: 05-21-2009, 09:53 AM
  4. Rear oiling port???
    By gixer2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:12 AM
  5. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
