Thread: Aem e85 fuel pump.
Results 1 to 17 of 17
  1. #1 Aem e85 fuel pump.
    Money vortex synysterjoe's Avatar
    Mar 2013
    Columbus
    Has anyone tried this pump?I'm having a bit of trouble visualizing this install, any help would be appreciated. I'm using it in a 2000 impala, so it shouldn't have a venturi pump. Any tips?
    Sent from my VS930 4G using Tapatalk
  2. #2 Re: Aem e85 fuel pump.
    SE Level Member charlieRobinson's Avatar
    May 2014
    OH
    Anyone have this pump installed?
    1999 Buick Riviera - L67
    PLX wideband +HPT pro +X-P HOT cam, 140#springs, 2x chain, LS7 lifted
    ZZP SS Headers + 3" Downpipe + 200 Cell Cat.+ Aero Resonator
    Gen V swapped L67, 60# injectors, E85, N*&LQ4MAF
  3. #3 Re: Aem e85 fuel pump.
    Mar 2014
    Tucson
    Yup
  4. #4 Re: Aem e85 fuel pump.
    Arizona
    Double yup
  5. #5 Re: Aem e85 fuel pump.
    May 2014
    OH
    Thanks, guys. Anything from your experience you can tell me to be ready for when I do mine? Any parts I should have handy to make it work?
    I am planning to install this pump in the next couple of days and converting to E85
    Thanks!
  6. #6 Re: Aem e85 fuel pump.
    Mar 2014
    Tucson
    Get the better hose clamps as shown in 91parkave's pic, and maybe some extra hose. I put a loop in my supply hose to prevent a kink. You going to solder the wires?
  7. #7 Re: Aem e85 fuel pump.
    May 2014
    OH
    Quote Originally Posted by BrandonHall10 View Post
    Thanks for the ideas. Yes, plan on soldering it.
  8. #8 Re: Aem e85 fuel pump.
    Apr 2015
    Columbus, OH
    Where did you find your clamps? I used the stock hose and clamps that came with the pump. Losing pressure as soon as I turn car off.
    I thought I read somewhere that the stock bendy hose holds up better to e85. You seem to be fine. Just regular fuel line?
    Top Swapped 01 Imp
  9. #9 Re: Aem e85 fuel pump.
    Mar 2014
    Tucson
    The stock corrugated hose is great, and would probably be best. In fact, I spent the $8 on a new one, but no matter what I did, I could not it on the pump outlet.
    I got the hose and the clamps at O'reilly. They had them behind the counter. Fuel injection rated clamps and hose. Supposed to handle the higher pressure of an EFI system. I think any EFI rated fuel hose should be safe for e85. The clamps were like $1.50 each.
  10. #10 Re: Aem e85 fuel pump.
    Apr 2015
    Columbus, OH
    You couldn't get the stock hose over the outlet? My problem is the aeromotive is smaller so I can't get it to seal. Was going to try some Permatex 1. I'd rather just have a good fit. Those clamps should help.
    Top Swapped 01 Imp
  11. #11 Re: Aem e85 fuel pump.
    Arizona
    Remember if you're gonna use regular rubber hose it must be rated for constant gasoline submersion don't just buy off the shelf
  12. #12 Re: Aem e85 fuel pump.
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    hmmmmm. ive def seen 2 posts in the last 6mo of these pumps burning up....
  13. #13 Re: Aem e85 fuel pump.
    Mar 2014
    Tucson
    Quote Originally Posted by danomite02 View Post
    Here?
  14. #14 Re: Aem e85 fuel pump.
    The Boss Iceman6669's Avatar
    Jun 2011
    I know a local that had issues with his also.
    2011 F-150 Yote powered
  15. #15 Re: Aem e85 fuel pump.
    Arizona
    Operator error?
  16. #16 Re: Aem e85 fuel pump.
    May 2014
    OH
    did you guys have a return line on your stock pump? The AEM pump has a hole there and the instructions to make sure it's not obstructed. What did you guys do with that?
  17. #17 Re: Aem e85 fuel pump.
    Mar 2014
    Tucson
    Show me the hole...
  1. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  2. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  3. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  4. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
