Thread: What should i do, performance or stock
Results 1 to 10 of 10
  1. #1 What should i do, performance or stock
    SE Level Member jjwalton77's Avatar
    Jul 2008
    Ames, IA
    If you read my other post, my belt on my supercharger broke. And now that i have to get a new one and figure out what happened to the first one. I was thinking, when replacing my belt (and possibly pulley) can i get a different pulley and belt to increase my performance (i have a cold air and will probably get a programed pcm in the summer) or should i get the stock kind. And if i do get the aftermarket pulleys and belts what size should i get?
  2. #2 Re: What should i do, performance or stock
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    I wouldn't be messing with pulley sizes till you get some decent exhaust mods like headers.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: What should i do, performance or stock
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    the S/C pulley is probably the most cost effective mod to do, its also the most likely mod that will cost you an engine lol. do some other work first ( CAI,exhaust etc.) and then once you know where your at do the pulley
    COMP G
  4. #4 Re: What should i do, performance or stock
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    A stock belt will work with a 3.5 pulley. A good running gtp can and will run a 3.5 pulley fine with no KR or very little. Now if your cat's plugged, then you could run into problems.
    I would personally throw on a stock belt and when your ready to mod, throw on a downpipe, 3.5 pulley and a tune/chip
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  5. #5 Re: What should i do, performance or stock
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by JJ91284 View Post
    I have to disagree with that. Lot's of people have 3.5" pulley setups that should in theory be able to run a 3.4" pulley no problem, but yet a lot of them still have KR problems. Hell I still have quite a bit of KR even with my setup, but that may have to do with it being winter and everything. Yes people used to be able to run 3.5" pulleys on near stock cars with little to no KR, but nowadays that is extremely uncommon.
    So my point is if your car isn't a factory freak, then select pulley sizes conservatively.
  6. #6 Re: What should i do, performance or stock
    Banned
    Wichita Falls, Texas
    If you want a pulley then get a 3.4/3.5 and put it on there. It's not going to blow your engine up dropping that small amount.
  7. #7 Re: What should i do, performance or stock
    Schaumburg, IL
    A 3.5 pulley won't damage your engine, unless their is a major fuel issue or excess back pressure from a cat issue. Even then, your PCM should be able to deal with it. A 3.5 pulley was used on the SLP GTX's and even the new newer 04+ gtp's boost more with the better/efficient gen V superchargers.
    You'll be fine on a 3.5 pulley.
  8. #8 Re: What should i do, performance or stock
    Jul 2008
    Dekalb, IL
    But I doubt it would make the car any faster. When I put my 3.4" pulley on when I just had a powerlog instead of the headers my car actually felt slower on top than with my 3.8" pulley on 18* of timing. Sure my car felt stronger from a dig but that feeling disappeared once I hit 2nd and starting getting a ****load of KR. There is no sense in doing a mod if it's not going to make your car much if any faster, all while increasing the risk of eventually chipping a piston.
  9. #9 Re: What should i do, performance or stock
    Quote Originally Posted by Smokin2000gtp View Post
    youre talking if youre tuning it and seeing what is best.
    stock vs stock, if you slap a 3.5 or 3.4 on the blower it WILL be faster.
  10. #10 Re: What should i do, performance or stock
    Jul 2008
    Dekalb, IL
    That's true, I forgot I've got the privilege of having a tuner lol.
  1. Performance Shifting
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2008, 12:59 AM
  2. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  3. Improve Performance
    By NSUstud in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 09:43 AM
  4. Best performance part you can buy for a stock GT
    By Dohner in forum PCM Tuning
    Last Post: 02-22-2008, 02:01 PM
