Heres what I got so far, I would have posted sooner but I was trying to help someone else troubleshoot, LOL.
Issue:
*Rough Idle
*Stalls
*SES Light (most likely a P0300)
*Wont restart
Work Done:
*Replace LIM gasket 3000 miles ago
*New Air Filter
*Fuel Pump can be heard activating and tested at the Schrader valve showing 42psi
*Spark at cylinders #1, 3 & 5, others were not tested
*New Spark plugs were installed, autolite 103's, gapped at 0.050".
*Replaced spark plug wires
*Replaced Fuel Pressure Regulator (Note: Started after replacing the FPR, ran for a few minutes and then died, again)
*Replaced MAP sensor
*ICM was tested and shows good.
*Replaced Crankshaft Position Sensor
*Replaced Camshaft Position Sensor.
