Thread: help needed imediatly!
Results 1 to 20 of 142
  1. #1 Re: help needed imediatly!
    Oklahoma
    Im not aware of any system that regulates the vacuum. Now its possible that you have a vacuum leak but I would have expected that to show up, at least in part, with your fuel pressure test, that is to say fuel pressure readings would have been off.
    So we know it starts, we know it started after your replaced the fuel pressure regulator. The first thing to do would be to start tracing out those vacuum lines and make sure they are all in good shape (no cracks, holes, etc) and are all connected.
    You kinda got me thinkin' you have a dual issue. Try and start it up this morning and let it run if it will start up. If it still just cranks and no start, post up here and let us know. I'll try and keep an eye on the thread, but I'll be at work so I cannot promise anything.
  2. #2 Re: help needed imediatly!
    PA
    Didn't read everything in detail. But did you try to unplug the MAF and start the engine that way? Might be a bum MAF sensor.
    2001 GSE
  1. MAF Tuning Help Needed
    By DanGTP in forum PCM Tuning
    Last Post: 10-09-2008, 10:10 PM
  2. Customization Help Needed.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-02-2008, 11:13 AM
  3. CarFax Needed
    By JJ91284 in forum Off Topic Discussion
    Last Post: 07-02-2008, 11:42 AM
  4. input needed
    By UWISHU1 in forum General Tech Discussion
    Last Post: 06-29-2008, 10:46 AM
