Thread: Misfiring after 100mph!
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 97
  1. #61 Re: Misfiring after 100mph!
    Twice the race.
  2. #62 Re: Misfiring after 100mph!
    GT Level Member ricio1991's Avatar
    Feb 2014
    Tempe
    I dont understand how u guys wonder how a gtp can do 90 to 100! Come on now its a comp g 100 shouldn't have a problem! Any regular car had go 100! A supercharged v6 hello 100 isnt limit. I had a eclipse gt that would do 100 easily with a 3.0. Are these cars really that bad in safety that i should worry about going 90mph?
  3. #63 Re: Misfiring after 100mph!
    You guys forgot to tell him all stock GP's have KR. You can have someone tune it all out even stock.
    Do the plugs blue said and gap them right, do the wires and coils. If you don't want to spend the money, start spinning your own wrenches.
    Replacing a cat, checking the maf and some of this other stuff is really not at all hard to do.
  4. #64 Re: Misfiring after 100mph!
    Quote Originally Posted by ricio1991 View Post
    No production car is really "safe" if you wreck at 90-100 mph
  5. #65 Re: Misfiring after 100mph!
    Here is what happens at 120mph
  6. #66 Re: Misfiring after 100mph!
    Donating User Odi's Avatar
    Chicago South Suburbs
    ^^ eh.
  7. #67 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    I know that tho I'm not always hitting 90mph but if i am i make sure its safe. Always keep up with tires and etc. but yeah if it anything happens at thats speed I'm done.
  8. #68 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Finally the light came on! Hopefully helps me makes me pin point problem, ima have mechanic check it out today
  9. #69 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    2 po300 random misfire codes! Going in today and checking everything out again and see what can be done
  10. #70 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    I need help. This doesnt look right anyone know what kind of hose goes where that dumb red thig is?
  11. #71 Re: Misfiring after 100mph!
    Yup simple solution would be to stop going 90-100 there's no reason to be going that fast unless it's the autobahn and then you wonder why the car is misfiring hmm
    04 Comp G.
  12. #72 Re: Misfiring after 100mph!
    Aug 2013
    McDonald PA
    That's supposed to be a vac line
  13. #73 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    I haven't gone that quick lately and its just random because it went on for about 20min and now its clear of codes. Im changing that hose. Its not even a hose!
  14. #74 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Im changing that out asap! Im at oreilley auto parts are the vac line universal? Like can i buy it here
  15. #75 Re: Misfiring after 100mph!
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Um. Should that not be the intake air temperature sensor??
    Sent from my SM-N900P using Tapatalk
  16. #76 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    It was the pcv line i just ordered one from gm
  17. #77 Re: Misfiring after 100mph!
    No that is a hard plastic line iirc.
    No intake air sensor is on the other side.
  18. #78 Re: Misfiring after 100mph!
    Aug 2011
    Michigan
    I gotchya. Looks like where my iat sensor goes =P
  19. #79 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    It says its called tube. Pcv! Got it for 5bucks plus shipping. Dealer didnt have it
  20. #80 Re: Misfiring after 100mph!
    Dec 2012
    troll land
    Btw op, with its 3.29 gears a comp g is s quicker but slower than a reg gtp with 2.93s
  1. 05 Misfiring
    By PontiacL32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 11:34 PM
  2. Misfiring
    By panheadred in forum General Tech Discussion
    Last Post: 04-25-2012, 11:16 PM
  3. Misfiring HELP!!!!
    By Grandprix07gt in forum General Tech Discussion
    Last Post: 03-07-2011, 04:17 PM
  4. misfiring
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 09:22 PM
  5. 24 MPG while averaging 100MPH!!!! Not too bad.
    By Morris 04 GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 07:28 AM
