Thread: Supercharger coupler replacement - Anaerobic sealant?
Results 1 to 12 of 12
  1. #1 Supercharger coupler replacement - Anaerobic sealant?
    Canada
    So I went to the dealership today, picked up some supercharger oil, and asked for some anaerobic gasket maker. He asked if it was for the intake or something, I told him it was going between the supercharger snout and the supercharger housing. He came back with some AC Delco "Engine Sealant" part number 88861418 which didn't say if it was RTV or anaerobic sealant on the box, so I thought it was the right stuff.
    But now that I can look it up, it says it's RTV. http://acdelcochemicalcatalogue.com/...hp?prod_id=129
    Is this right or did the guy not give me the right sealant?
    Also, when sealing up the supercharger does both sides of the housing need to have sealant or just the snout?
    Thanks in advance. It's a 1997 Grand Prix GTP.
  2. #2 Re: Supercharger coupler replacement - Anaerobic sealant?
    I used red RTV on mine and ive never had any issues. Just spread it on the snout and snug her up.
  3. #3 Re: Supercharger coupler replacement - Anaerobic sealant?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Both sides of the rotor pack housing need the sealant.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  4. #4 Re: Supercharger coupler replacement - Anaerobic sealant?
    Gray or copper rtv here!
    04 Comp G.
  5. #5 Re: Supercharger coupler replacement - Anaerobic sealant?
    hangover park IL
    i have the giant 1.69 fl oz tube of GM gasket maker (loctite anerobic sealer rebadged for GM) GM# 1052943
    rtv is not ideal as more than a fingerprint thick can shoot a good amount of rtv towards the gears as its tightened down...people use way to much rtv it seems lol
    ive pulled apart a blower with rtv shredded all through the gearbox.
    i prefer to use the anerobic sealer (without hardener, easier for future repairs and it seals just fine without it...easier to cleanup) as we are talking about a component where you dont want excessive runout to prematurely wear out bearings and seals/parts/rotors/case
    ~James~ Psychotic Gearhead
  6. #6 Re: Supercharger coupler replacement - Anaerobic sealant?
    The Boss Iceman6669's Avatar
    Jun 2011
    I used the AC delco stuff and it appears mine isn't leaking.
    2011 F-150 Yote powered
  7. #7 Re: Supercharger coupler replacement - Anaerobic sealant?
    I used; http://www.permatex.com/products-2/p...sealant-detail
    We have tons of little 30ml tubes laying around at work, did the job just fine!
    Where are you located? Maybe you're close to me...
  8. #8 Re: Supercharger coupler replacement - Anaerobic sealant?
    Canada
    Quote Originally Posted by Damnir View Post
    Victoria, BC
  9. #9 Re: Supercharger coupler replacement - Anaerobic sealant?
    Ah, thought you might be closer! That's about as far as you can get!
  10. #10 Re: Supercharger coupler replacement - Anaerobic sealant?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Turbocharged400sbc View Post
    Also people seem to not know that when using RTV as a gasket between two smooth surfaces and not as a filler, you are supposed to let it get tacky before you assemble and torque down.
    7"
  11. #11 Re: Supercharger coupler replacement - Anaerobic sealant?
    Same tube here and ... always less is more in this case.
  12. #12 Re: Supercharger coupler replacement - Anaerobic sealant?
    Nov 2011
    NY
    Sealant is needed there?
    oh my...
  1. Replacement Supercharger Coupler
    By eshina17 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2012, 07:28 PM
  2. coupler replacement
    By Fox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 11:47 PM
  3. Supercharger coupler replacement
    By Beelzeboul in forum General Tech Discussion
    Last Post: 07-25-2012, 08:47 PM
  4. Supercharger coupler replacement
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 04:58 PM
  5. New coupler and rotor replacement
    By gtpcruizer in forum How To Write-Ups/Tech Tips
    Last Post: 07-13-2009, 04:26 PM
