I have a build thread for this Impala http://www.grandprixforums.net/threa...-SS-quot-build
The plan at first was XP/105's etc.
That changed to XPZ/130's/double roller chain
Cliffs on the engine build for those who havent read the build thread...
diamond +.020 9.5:1
ported heads
ARP everything
E85
Phenolic full size IC
Gen V/ 2.7" pulley + 5% OD
Now I have a recent influx of cash put down to move forward with the project and the time has come to order the cam. We were pretty final on putting a XPZ in it but after reading about valve guide failures and complications with valvetrain geometry at high lift it has me wondering.... Is it really worth it to put a XPZ in a street car? Will it EVER be reliable enough to drive 1000 miles out of state with a big cam? How much power will an XPZ or IS3 really make over something much simpler like a XP? The owner isnt 100% automotive competent, if he has issues and the timing cover or heads have to come off he will be stuck trying to find a shop that is competent enough to understand the setup and that is willing to deal with it.
Also IF we do go with a big cam which one is actually the best choice for this setup? I have read through ZZP's not-so-technical info about the XPZ, many threads on 3800Pro regarding XPZ vs. IS3 and Intense racings own IS3 Vs. XPZ write up (http://www.intense-racing.com/cam_comp/index.html.) Another thing that has me questioning all that I know is that ZZP claims they made 464hp with a XPZ. Intense racings own test data shows just under 400 for both cams even with a M112 on the motor! They also show with a M90 they only made 340 whp with a IS3 and CNC heads? A funny thing about their data is that the XPZ setup they tested made 5 less HP but made +10 ft-lbs which they dont mention in their take on the numbers. That sounds like a fair trade off to me and is still swinging me towards a XPZ. We were thinking we would like to potentially make as close to 400whp as possible with a genV M90 but that is looking pretty IMpossible at that rate.
