Thread: No temp gauge, cold radiator!
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: No temp gauge, cold radiator!
    Aug 2013
    arlington, tx
    Sounds like you have a short in there somewhere. Exact same thing that happened to me. Your multimeter will be your best friend for this fix. When you first turn on the car, will your temp gauge go all the way up and then down again like the others?
  2. #22 Re: No temp gauge, cold radiator!
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    put the stock 195 back in, your mpg are suffering. so it is hurting it somewhat. your engine wa made to run at 210 deg's. thats where it runs its most efficient.
    My temp gauge was reading just over the very bottom line(70 I believe) then I put in the 180 tstat and it jumped up to the 1/4 mark, just under.
  3. #23 Re: No temp gauge, cold radiator!
    SE Level Member crysalis's Avatar
    Mentor, OH
    Forgot to reply!
    Tested wiring and the sensor with my multimeter... All was fine. I let the car sit for a couple more days before I took it to my friend. I started her up and all was perfectly normal. Temp readings have been 100% normal ever since. Gauge is fine.
    Completely strange.
    2006 GP GT S/C | CAI | Overkill PCM | PLOG | 3" Catted DP | ZZP Strut Brace -- SOLD the car in treason for a Hemi Charger >:]
  4. #24 Re: No temp gauge, cold radiator!
    Mar 2014
    Canada
    Hmm
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    By 99GTPJay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 07:26 AM
  3. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
