Thread: No temp gauge, cold radiator!
Results 1 to 20 of 24
  1. #1 Re: No temp gauge, cold radiator!
    Quote Originally Posted by Dustoff View Post
    I have a similar problem with my 02 gtp. I swapped the stock tstat to a 180 degrees and now the temp gauge sits just under the 1/4 line, maybe a tick under or 2. Seems to warm up if I drive it in traffic then once on highway will drop again... Hasn't hurt anything. Would love to fix this issue tho let me know if u find a fix.
    put the stock 195 back in, your mpg are suffering. so it is hurting it somewhat. your engine wa made to run at 210 deg's. thats where it runs its most efficient.
  2. #2 Re: No temp gauge, cold radiator!
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    My temp gauge was reading just over the very bottom line(70 I believe) then I put in the 180 tstat and it jumped up to the 1/4 mark, just under.
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    By 99GTPJay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 07:26 AM
  3. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
