Thread: Noise from engine bay
Results 1 to 15 of 15
  1. #1 Noise from engine bay
    Dec 2013
    NW Indiana
    I have an 01 gtp bone stock and have a rubbing/grinding type noise coming from the passenger side of the engine bay. It goes away after giving it some throttle. At first after researching I thought sc coupler but I disconnected the sc belt and turned the pulley on the sc and it had no play to it. I also started the car and it still made the noise while the sc belt was off so I know it's not that. The bad thing is I don't have a heated garage and it's been really cold in combination of me workin 60-70 hrs per week so my time is limited.
    Maybe water pump? Even though no visible leaks nor overheating
    I recently changed idler pulley and the car has 113k on it. It also had a list of stuff done when I bought the car. Sc gasket, valve cover gasket, sc oil change, brakes, cv boots, thermostat and some others I can't think of off the top of my head.
    Any help would be appreciated
  2. #2 Re: Noise from engine bay
    Feb 2013
    37.295091, -121.930053
    try turning on your ac when your engine get warmed up. I had a bearing rattle and that was my problem so try that if it goes away then your ac bearing is bad...
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Noise from engine bay
    you hear this in park. or when rolling slowly?
    if its in park take both belts off, then fire it up for a minute, if theres no more sound its a pulley or engine pulley. a/c. water pump. ps pump, or alt or tensioner.
    if its only when rolling, check the dust shield on the brake rotor, sometimes they get bent and rub the rotor. could of happened during the brake job.
  4. #4 Re: Noise from engine bay
    Dec 2013
    NW Indiana
    K. I'll do that before throwing money at it. Thanks for the speedy input.
  5. #5 Re: Noise from engine bay
    Feb 2013
    pics of your ride would be nice too lol
  6. #6 Re: Noise from engine bay
    Dec 2013
    NW Indiana
    It's both in idle in park and in drive at a stop. Once I get to 2k rpm it goes away.
  7. #7 Re: Noise from engine bay
    Dec 2013
    NW Indiana
    I gotta wash it first It's a coupe, red with the 3 spoke rims.
  8. #8 Re: Noise from engine bay
    turn the ac on or defroster should turn the a/c compressor on, if the sound is gone the a/c clutch is wearing out. some have sprayed lube inside the a/c clutch and it seems to work. for how long idk......
  9. #9 Re: Noise from engine bay
    Dec 2013
    NW Indiana
    It's making the noise when defrost is on. I know that for sure
  10. #10 Re: Noise from engine bay
    Feb 2013
    wait scotty your aggreeing with me lol
  11. #11 Re: Noise from engine bay
    its one thing that will screech. so sure why not lol
  12. #12 Re: Noise from engine bay
    Dec 2013
    NW Indiana
    It's not a screeching but more of a whirring/grinding similar to bad brakes
  13. #13 Re: Noise from engine bay
    grinding, a/c compressors do that too.
    if you look at it car running, just the outside where the belt is that turns, when its on the whole hub turns. the bearing in the clutch fails and then it makes bad sounds when the a/c is off.
  14. #14 Re: Noise from engine bay
    Feb 2013
    that is your ac brearing, ps, water pump making that sound.
  15. #15 Re: Noise from engine bay
    Dec 2013
    NW Indiana
    Well the car is at my in laws as they have a heated garage and the car will stay there overnight. I gotta go to work the gym then work in a couple hours so I'll more than likely get it done in the morning after I get home.
  1. Engine Noise?
    By mrdbaby in forum Engine
    Last Post: 10-09-2013, 09:53 AM
  2. GXP Engine noise
    By rguy200073 in forum 5.3L V8 (LS4)
    Last Post: 05-11-2013, 11:35 AM
  3. Engine noise
    By Mrjcuhh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2012, 05:31 PM
  4. Engine noise
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2010, 10:03 PM
  5. Engine noise help please.
    By mathd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2008, 08:50 AM
