Thread: power steering noise
Results 1 to 6 of 6
  1. #1 power steering noise
    Florida
    Changed my front rotors the other day and now have power steering whine. Now prior to this never had any noise from there at all. The only out of ordinary thing I did was turn wheel all the way when I did each side to have better access to caliper bolts. So I'm thinking that's what made this occur, and its more then likely air so how would I bleed the system or fix this?
  2. #2 Re: power steering noise
    check the fluid level, if its full the pump is dying. had nothing to do with the turning the wheels to do the calipers. i do the same thing.
    once its bled. air cant get back in the lines pump or rack from turning it, even if the car is off. only a broken line will cause air to get inside.
  3. #3 Re: power steering noise
    Florida
    and i only hear the whine when taking off,nothing when turning. plus it's intermittent,like itll disappear but usually on startup and driving first few 10-15 its heard.
  4. #4 Re: power steering noise
    if you still have power steering, drive it till the pump stops working or whines like mad.
  5. #5 Re: power steering noise
    Florida
    just an update,turns out i was just low on fluid. added about half a jug and whining is gone. No apparent leaks but will keep monitoring.
  6. #6 Re: power steering noise
    SE Level Member Zm04gtpcompg's Avatar
    Sep 2013
    Cissna Park, IL
    It's leaking into the boots rack and pinion seals are leaking
    Sent from my iPad using Tapatalk
  1. Replaced Power Steering pump, now making noise.
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 05-14-2011, 03:06 PM
  2. steering noise HELP
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2011, 01:28 PM
  3. Power Steering noise..
    By bryanAZ97GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-24-2010, 06:00 PM
  4. Power steering noise
    By Dott in forum General Tech Discussion
    Last Post: 11-30-2009, 01:10 AM
  5. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
