Thread: yt 1.9 problems
Results 1 to 18 of 18
  1. #1 yt 1.9 problems
    Sep 2013
    Massachusetts north shore
    I installed my yt 1.9 and 105 springs a few weeks ago and i was in such a rush to get out of the shop i really didnt pay as much attention to aligning the rocker to the valve as much as i should have i know the tip of the rocker is on the valve at the time i was under the assumption that it centers its self when tightened down i did not notice that there was a little play on the rocker arm and pedistal till i was done with the back and now i am thinking of opening it back up just to check and center them is this necessary
    I noticed my valvetrain got a little louder i can hear a faint tapping at idle i have heard other cars louder than mine but it was quieter before is this common with yt rockers
    I also noticed a slight vibration at 900-1100 rpm i cant remember if it was there before
  2. #2 Re: yt 1.9 problems
    time to take the vc's off and check them out.
  3. #3 Re: yt 1.9 problems
    Pennsylvania
    With YT rockers, you definitely need to use the pushrods they give you, they're a different length than stock... a little longer, I think.
    Sport Edition Kv5 18x8
  4. #4 Re: yt 1.9 problems
    Wouldn't be a bad idea to recheck the rocker bolt torque.
  5. #5 Re: yt 1.9 problems
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Agreed with all the above. YT's are a perfect fit every time I've installed them. Make sure you used the pushrods that came with them. Take off valve covers and check to see if they are lining up and loosen, adjust, and re-torque them. Use a dab of red locktite on the threads.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  6. #6 Re: yt 1.9 problems
    Sep 2013
    Thanks for the advice but are they a little louder than stock kinda like a honda
  7. #7 Re: yt 1.9 problems
    Jan 2013
    Australia
    make sure you get any oil out of the rocker bolt holes... otherwise you won't reach the proper torque spec
  8. #8 Re: yt 1.9 problems
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I didn't notice any noise from the rockers. Sounded like stock.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  9. #9 Re: yt 1.9 problems
    Sep 2013
    Thanks guys for all your advice i tore into it yesterday and found them all perfectly lined up i did buy them used and have a slight side to side play on all the rollers but didnt think it is my problem i am now thinking maybe the lifter is a little weak but the noise is a faint taping so i am not very concerned
  10. #10 Re: yt 1.9 problems
    Florida
    hows the performance? pulls good?
  11. #11 Re: yt 1.9 problems
    Sep 2013
    I honestly cant tell you i lost my lic it feels like i might have lost a little low end torque but i think i might have gained some on the top end the exhaust has gotten a little louder i have sd headers and a cat back
  12. #12 Re: yt 1.9 problems
    Sep 2013
    I also installed the intense oil pressure kit without the washer i was thinking with the yt pushrods my oil pressure would be to high but now i am reconsidering i am going to install a oil pressure gauge at work and see where its at with and without the washer intense said the spring is stock so whats the difference with zzp kit i was under the impression that 2004 and up had a higher pressure
  13. #13 Re: yt 1.9 problems
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    My Harland sharp 1.9's were slightly noisy for a couple weeks after install with 105 crows. They are completely quiet now though.
    I wouldn't say anything is wrong, probably just weak plungers in the lifters.
    Sent from Not so smart smartphone
  14. #14 Re: yt 1.9 problems
    Dec 2008
    Alabama
    The rockers don't effect oil pressure. They rely on a small amount of oil coming up through the holes in the pushrods that the lifters provide. The oil gets squirted on the top of the rocker providing lubrication. Is that faint tapping noise there all the time, or does it come and go? My thought is a fuel injector is starting to go out. The 04's do have about 5 psi. or so more oil pressure. Iirc., that is why the newer 3800's run 5w-30.
  15. #15 Re: yt 1.9 problems
    Sep 2013
    I figured that with the oil restricted pushrods and a new spring the pressure would rise in the rest of the system
    The noise is when the engine is hot
  16. #16 Re: yt 1.9 problems
    Sep 2013
    It more pronounced after reving the engine and it seems like one or two rockers are louder than the rest on each head i am also thinking that if it was a injector it would not be as loud when the engine is decelerating after reving it thats when its more pronounced
  17. #17 Re: yt 1.9 problems
    Sep 2013
    It wouldn't hurt to do a injector balance test or just un plug it to be sure to rule out it did cross my mind
  18. #18 Re: yt 1.9 problems
    i would have ran it with no valve covers and watched and listened to them. they sell clips that cover the oil hole on the rocker so oil dont shoot all over.
    you can grab each rocker while its running and feel if one is loose.
  1. A/C problems
    By TEK310 in forum General Tech Discussion
    Last Post: 06-10-2012, 01:21 PM
  2. maf problems... A G A I N!!
    By tc300 in forum General Tech Discussion
    Last Post: 05-20-2012, 11:25 PM
  3. A/C problems
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:04 PM
  4. a/c problems
    By ddyke2000 in forum General Tech Discussion
    Last Post: 06-23-2009, 06:15 PM
  5. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
