Thread: Vacuum leak? after ic install
Results 21 to 40 of 42
  1. #1 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Keep clicking, it will
  2. #2 Re: Vacuum leak? after ic install
    Florida
    Hrm....I'm unsure if the PCV is drilled differently between the cores. Though to get it working correctly you should drill the LIM so that it matches the IC core PCV hole, plug the nipple, and have the front VC/oil cap/LIM tapped and run a vacuum line to the intake between the MAF and butterfly.
  3. #3 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Yeah it's hard to say, I've been double checking n reading up on all this the last few days, I drilled n tapped a hose barb in the front of the lim n running
    then today, I noticed that back right hole didn't match with my rear pcv, the core has the hole then milled inside n goes over an inch or so and has a different hole coming out so I drilled this to retain the rear pcv.
    its harder to say though since yours is the gen 3 core and the older wbs, or thrasher or w.e it is. You just gotta look thru and see which holes you have and don't have on both the core and your lim.
  4. #4 Re: Vacuum leak? after ic install
    Florida
    What I would do (and I know it sucks) is take the blower and IC core off, clean all the RTV off, and use something to make a circle around the PCV hole in the IC core (lipstick works great) and set the IC core on the LIM. That'll show where to drill for the PCV to get the rear operational.
  5. #5 Re: Vacuum leak? after ic install
    I'll see about doing that tonight. It'll only take about an hour or so.
  6. #6 Re: Vacuum leak? after ic install
    The wife gave me 30 min in the garage so this is all the further i got. I have oil all over where the egr goes into the sc. It also seems i have a gen v core because it mounts up perfect to the gen v and the pcv holes seem to be lined up just right.
  7. #7 Re: Vacuum leak? after ic install
    well that dont look so good does it?
  8. #8 Re: Vacuum leak? after ic install
    Florida
    Run your finger inside the PCV opening and see if that oil/moisture mixture is the same as that mess by the EGR hole. If so, my guess is that the rear PCV is block and causing excess pressure, and it's escaping through there.
  9. #9 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Hmm, any idea why that would be happening?
  10. #10 Re: Vacuum leak? after ic install
    Florida
    Hrmm...well the PCV lines up from the SC to the IC core, but does the IC core PCV line up to the LIM PCV??
  11. #11 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Yeah, show the bottom of the ic core..look at holes to see lined up. I thought since mine had the holes thru the ic on the top and bottom I was okay, until I found out the we're positioned differently and milled thru the middle of the core and slightly positioned. Hence I drilled thru the lim to create passageways.
  12. #12 Re: Vacuum leak? after ic install
    The 2 holes line up the whole way through. I found a little oil there before I did the install bit didn't think anything of it. It's also been burning a little oil on each start up. So my rear pcv is probably clogged? Can I just pull my rear valve covert and see?
  13. #13 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    I wouldn't know man so I couldn't tell ya about all that. I have no clue how it'd get like that.
  14. #14 Re: Vacuum leak? after ic install
    you still have a egr on there? if so pull it off and see if its also coated in oil.
  15. #15 Re: Vacuum leak? after ic install
    No egr. It's been gone for a long time.
  16. #16 Re: Vacuum leak? after ic install
    Mercer, Pa
    Which intercooler? BBK ????e.. Do you have pictures of just intercooler or better pictures.
    It looks like the intercooler PCV holes are drilled straight through If that is the case you may not have to do anything for the PCV. It will work like stock.
  17. #17 Re: Vacuum leak? after ic install
    Not sure if the make of the ic. I've been told it's like the old wbs. I'll post better pics tomorrow. The pcv port runs into the rear head right? So I should be able to pull the rear vc and clear whatever is blocking it?
  18. #18 Re: Vacuum leak? after ic install
    Florida
    No, there's nothing in the head/VC that would "block it" it's a series of passageways that allow fresh air in and out of the crank case. Basically, as long as the BOTTOM of the IC Core PCV hole lines up with the LIM PCV hole, you're golden.
    As far as the oily ****, my guess is contaminated oil from improper PCV operation.
  19. #19 Re: Vacuum leak? after ic install
    So the pcv valve in the sc might not be working Right?
  20. #20 Re: Vacuum leak? after ic install
    Ok so my front pcv was blocked. I fixed it
    My fix for the rear one
    Will my icm be ok like this?
  1. Odd vacuum leak?
    By Dallasneon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2012, 01:21 AM
  2. Vacuum Leak?
    By crock in forum General Tech Discussion
    Last Post: 08-21-2011, 12:09 AM
  3. Vacuum Leak Help
    By RichardL12 in forum General Tech Discussion
    Last Post: 06-03-2010, 06:28 AM
  4. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  5. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
