Thread: Vacuum leak? after ic install
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Vacuum leak? after ic install
    I'm having problems with my car after my ic install. I think i have a vacuum leak but can't find it anywhere. I'm using a gen 3 ic core and gen v supercharger.
  2. #2 Re: Vacuum leak? after ic install
    Mar 2012
    NC
    Did you use gaskets or RTV?
  3. #3 Re: Vacuum leak? after ic install
    rtv
  4. #4 Re: Vacuum leak? after ic install
    Mar 2012
    NC
    How long did it sit and are you 100% positive you didn't move anything and set it down perfectly straight? Ask me how I know...:/
  5. #5 Re: Vacuum leak? after ic install
    I know it's all good because i had to pull it back off and fix a coolant leak. I used threaded rod so it just sit right down straight. I left it sit for about 1-2 hours before i torqued it down.
  6. #6 Re: Vacuum leak? after ic install
    Banned
    Jan 2013
    maryland
    Where was your coolant leak at?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  7. #7 Re: Vacuum leak? after ic install
    At the 2 spots I didn't block off good enough.
  8. #8 Re: Vacuum leak? after ic install
    Mar 2012
    NC
    You let it sit before torquing? I torque then wait a day. Never had a leak that way. Your way I have though because the RTV doesn't want to sit flat. May or may not be the issue. I also use UltraGrey...that stuff might as well be liquid aluminum as far as I'm concerned.
  9. #9 Re: Vacuum leak? after ic install
    I used copper rtv. I waited to start it until the following day. I finger tightened the bolts with a socket then waited a little bit then torqued down after a while.
  10. #10 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Is it the hole in your oil cap?
  11. #11 Re: Vacuum leak? after ic install
    I do have a hole in the oil neck.
  12. #12 Re: Vacuum leak? after ic install
    Florida
    What makes you think you have a vacuum leak? Pegged fuel trims and low vacuum??
    I've never let RTV sit before torquing. I have always put it on, torqued it, then let it sit for 6+ hours.
  13. #13 Re: Vacuum leak? after ic install
    I'm not sure it's a vacuum leak for sure. Ft's are fine. Does the rear pcv need to be vented if i have a homemade breather on the front? It'll randomly cut out while accelerating and run really lean when getting on it then randomly peg out my wb rich at WOT.
  14. #14 Re: Vacuum leak? after ic install
    Florida
    Whats your vacuum at idle?
    Usually a vacuum leak will cause your trims to be off at idle, I had a small leak and was always +16.4 LTFT, though driving they were fine.
    Did you drop pulley sizes yet or change the tune any?
    How is your rear PCV setup? Drilled the LIM for the core to match up and capped the nipple on the Gen V?
  15. #15 Re: Vacuum leak? after ic install
    should the pcv be working normal? if so seal that hole in the neck for sure.
    if not you need to re route the pcv.
  16. #16 Re: Vacuum leak? after ic install
    I didn't drill the LIM for the rear pcv but I did cap the nipple. Didn't drop pulley or change the tune either. I have my Icm shimmed up would that cause it to not work right? I show no misfires at all.
  17. #17 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Take off the oil cap n put your hand up to it with the car running, see if it sucks it. If it does, you'll need to route a pcv passage a believe.
  18. #18 Re: Vacuum leak? after ic install
    pcv I don't think will work right since I'm running a gen 3 core on a gen v
  19. #19 Re: Vacuum leak? after ic install
    Feb 2013
    Detroit, MI
    Hmm then you prob gotta figure out a way to run all that. Here's something I've dug up. I'm trying to figure all this out right now too because I don't wanna have problems after I put my ic on.
    http://www.clubgp.com/newforum/tm.as...heck=373343081
    http://www.thechicagogarage.com/foru...ing-peeps.html
  20. #20 Re: Vacuum leak? after ic install
    link didn't work.
  1. Odd vacuum leak?
    By Dallasneon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2012, 01:21 AM
  2. Vacuum Leak?
    By crock in forum General Tech Discussion
    Last Post: 08-21-2011, 12:09 AM
  3. Vacuum Leak Help
    By RichardL12 in forum General Tech Discussion
    Last Post: 06-03-2010, 06:28 AM
  4. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  5. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
